Edge EZ
Old Aug 20, 2007 | 10:42 PM
bway4x4's Avatar
bway4x4
Default Edge EZ
Just bought an Edge EZ Module. I was just wondering if anyone is using this module, and how hard it is to install, and how they like it. Any info is much appreciated. (2004 2500 CTD QC 4x4)
Old Aug 21, 2007 | 02:04 AM
Mayfair's Avatar
Mayfair
Default RE: Edge EZ
I'm thinking about the same one. The install looks pretty simple. If you could, take pics as you go, especially how you change the settings. The more detailed the better.
Thanks !!
Old Aug 21, 2007 | 12:16 PM
MrSlug's Avatar
MrSlug
Default RE: Edge EZ
Can't say much about the EZ. The Juice was pretty straight forward with the only PITA being connecting up the turbo timer (just because its a small space). I believe the EZ has fewer connections, so should be a piece of cake.
Old Aug 21, 2007 | 08:36 PM
bway4x4's Avatar
bway4x4
Default RE: Edge EZ
Is the 65-75 Horsepower that the EZ claims gonna be real noticeable or not? (My first +HP mod)
Old Aug 21, 2007 | 10:15 PM
solarwarp's Avatar
solarwarp
Default RE: Edge EZ
I have the EZ, the dealer installed it... not sure if the power is not really noticable on daily driving, maybe if towing.
I do think that punching it from 35-70 is a tad bit more fun, plus I blowa littl black smoke.
Old Aug 22, 2007 | 05:27 PM
racevoodoo's Avatar
racevoodoo
Default RE: Edge EZ
I installed an EDGE EZ a few months ago. Took maybe 20 minutes and that was reading the instructions over a couple of times. Very easy! Yes, it makes a noticable amount of power! I tow a 26 ft. enclosed race car trailer and it makes all the difference in the world on hills and against the wind. I have mine set on the #1 setting (mild) and it does all I need. I haven't even tried the other two settings. I installed an EGT gauge and boost gauge at the same time. Temps always stay below 1300 deg. and are usually 900-1000 towing in 90-95 deg. weather. I've never seen 1300 deg. even on a big hill. I suppose you would need to watch the temp. a little closer on the higher settings. As I said, the power is very noticable! It is a lot of fun running empty, feels like a hotrod. Have fun.
Old Aug 22, 2007 | 05:37 PM
gtxpooch's Avatar
gtxpooch
Default RE: Edge EZ
I installed the Juice/Attitude about a month ago and can't tell any difference at any of the 3 lowest sttings. I haven't tried it on 4 or 5but Ihit 1400 deg. going up Vail Pass in Colorado real easy on setting #1. And the mileage still sucks!
Old Aug 22, 2007 | 09:58 PM
bway4x4's Avatar
bway4x4
Default RE: Edge EZ
So the Edge EZ will allow me to blow "some" smoke? Mine should be arriving within a day or two, hopefully i have no problems installing it.
Old Aug 23, 2007 | 01:52 PM
Mayfair's Avatar
Mayfair
Default RE: Edge EZ
ORIGINAL: racevoodoo
How do you change the settings from 1-3?
What are the differences?
Pics would be awesome !! I'm tossing back and forth between the EZ and the Comp.
Old Aug 23, 2007 | 08:38 PM
bway4x4's Avatar
bway4x4
Default RE: Edge EZ
Not totally sure Mayfair, haven't gotten the delivery yet. However, I believe level 1 is mostly just for better mileage and a slight hp gain, 2-3 more hp a total of up to 75 i believe. As far as adjusting power levels the module has 2 torque screws that hold the cap on, and you have to move the jumpers to set the power level.
