High Speed Idle
Old Aug 23, 2007 | 01:36 PM
zixxer10r's Avatar
zixxer10r
Default High Speed Idle
I have a 03 2500 and i was told by the dealership that there is no way I can Activate the High Idle on this year truck. Is this true?
Old Aug 23, 2007 | 06:23 PM
FroneDaddy's Avatar
FroneDaddy
Default RE: High Speed Idle
They're right, you have the automatic high idle, however on ouryear we don't have the manual feature.
Old Aug 24, 2007 | 07:50 AM
Drew's Avatar
Drew
auto's are easy. . .it is just a matter of hooking up the computer to it and enabling it. . .if you have a manual trans, you just need to ground pin22 ECM connector B and then have it enabled
Old Aug 24, 2007 | 10:16 AM
JDH's Avatar
JDH
It is my understanding for the 03's you need TSB 18-004-04 you can look at the details at WWW://.dodgeram.info/tsb/2004/18-004-04.htm
It is a flash for poor cab heet and/or slow engin warm up in cold ambient temp.
reade all the details to find out if this applies to your truck, it gives complete instrucions so the un-informed dodge tech can perform the flash and activate the Idle-up feature.
If you ask them about a high idle feature they will not find it because it is not called that.
I have not had it done on ine but will befor winter this year.
Old Aug 24, 2007 | 10:19 AM
JDH's Avatar
JDH
Link is http:/www.dodgeram.info/tsb/2004/18-004-04.htm
I typed it wrong the first time.
Old Aug 24, 2007 | 02:25 PM
UpBranchLiner's Avatar
UpBranchLiner
Lets say you fire up your CTD and its 10 degrees out. Do you wait for a minute or so before you turn on the high idle? or go right to high idle?
Old Aug 24, 2007 | 06:21 PM
FroneDaddy's Avatar
FroneDaddy
http://dodgeram.info/tsb/2004/18-004-04.htm
For those of you who just want to click
