Turbo timer install ?s
Old Aug 24, 2007 | 06:00 AM
Cumminside's Avatar
Cumminside
Default Turbo timer install ?s
I'm HORRIBLE with wiring diagrams, and I don't kow if I've found the right one. Could someone please tell me what the wire colors are for the power( most likely red) accessory andRunin the 2006-2007 CTD Ram 2500. I have the 6.7, but I'm pretty sure they woulding change the whole ignition harness for that. I'm attempting to install a Blitz FATT DCIV turbo timer into my truck. I just had it laying around, so I was thinking, what the hell, lets put it on the truck.
Thanks in advance!
Old Aug 24, 2007 | 02:48 PM
NCcummins's Avatar
NCcummins
Default RE: Turbo timer install ?s
to go along with your post...are turbo timers nessary? if so, is there an edge juice that comes with one in their system?
thanks!
Old Aug 24, 2007 | 04:42 PM
gtxpooch's Avatar
gtxpooch
The instructions I got with mine were pretty clear on which wire goes where.
Turbo timers necessary? Depends, I guess. I like mine because when I pull infor fuel on a trip I don't have to wait, i can start fueling while the truck is cooling down. a lot of diesel owners have a tendency to shut them off as soon as they stop the vehicle which isn't good. JMHO..
Old Aug 24, 2007 | 04:50 PM
cmnspwr's Avatar
cmnspwr
Turbo timers, in my opinion, are useless. Just wait until your EGT's are about 300* then shut it down. As gtxpooch said, just leave it running while getting fuel.
Old Aug 25, 2007 | 12:40 PM
moconst's Avatar
moconst
its in the steering column, easy to find. just a plug and your done
Old Aug 25, 2007 | 02:05 PM
gtxpooch's Avatar
gtxpooch
Directions on my Edge say to connect the red power wire to fuse#30(15amp spare fuse) and reinsert with the supplied fuse tap, making sure you allow for clearance of the fuse box lit. You may have to squeeze it with needlenose pliers to make it fit. Hope that helps
