Rattling // Pecking
Old Aug 26, 2007 | 01:30 AM
Kev_n_AZ's Avatar
Kev_n_AZ
Default RE: Rattling // Pecking
take floor jack and lift each wheel off the dround. spin them by hand and listen. if its a hub cap, or bearing you should hear it.
with the wheel up, carefully look for rocks and other FOD in the tread before lowering it back down.
if all else fails, run throguht he under cariage and greesa every point you can. if the noise goes away, then its a bearing or u joint.
Old Aug 26, 2007 | 01:47 AM
bway4x4's Avatar
bway4x4
Could it be a tranny problem though?
Old Aug 26, 2007 | 01:48 AM
Kev_n_AZ's Avatar
Kev_n_AZ
take it one thing at a time.
maybe, maybe not a trans prob.
could judt be a u joint thats worn.
noises are some of the hardest things to figure out.
Old Aug 26, 2007 | 01:55 AM
bway4x4's Avatar
bway4x4
Alright, Ill jack it up in the morning and see if i can't figure something out.
Old Aug 26, 2007 | 01:58 AM
Kev_n_AZ's Avatar
Kev_n_AZ
make a list of what you have checked as you go...then it shortens your suspicions..unlike a restless woman!
Old Aug 26, 2007 | 02:08 AM
bway4x4's Avatar
bway4x4
To check the U-joint i have to remove it right? Because i grabbed the driveshaft and there is no play in it, but i know that doesn'ttotally mean that the u-joint is fine... I don't know if this info helps any, but the knocking noise is there ONLY while moving. I hear it whether im in gear, or bumped in neutral coasting, whether im accelerating or slowing down.. However when i'm almost to a complete stop, 5-15 mph the noise goes away. Does this strike any new ideas? Also, what should i check first?
Old Aug 26, 2007 | 02:12 AM
Kev_n_AZ's Avatar
Kev_n_AZ
greesa the u joints. that will cushion a bad u if its shot. noise should subside for a day or so. otherwise yank em and replacem..all of em..maybe even the carrier bearing while your down there!!!!
Old Aug 26, 2007 | 02:15 AM
bway4x4's Avatar
bway4x4
May i ask what the carrier bearing is? Not familiar with that one.
Old Aug 26, 2007 | 02:18 AM
Kev_n_AZ's Avatar
Kev_n_AZ
ORIGINAL: bway4x4
run your hand down the shaft...when you hit the big hump in the middle you found it.... the follow past to the rear end...
Old Aug 26, 2007 | 02:19 AM
bway4x4's Avatar
bway4x4
Ok will check that as well, thanks alot baja, i'll post what i find tomorrow.
