question for anyone who works on ctd
Old Aug 25, 2007 | 10:13 AM
MCDiver's Avatar
MCDiver
Default question for anyone who works on ctd
I have the 24 valve in a 01 dodge. It appears that there is an oil leak behind the harmonic balancer (if the diesel calls it the same thing as a gasser). I would assume it is the front crank seal. Is this replacable withoug disassembling the engine?
Old Aug 25, 2007 | 01:29 PM
Parts/Service's Avatar
Parts/Service
Default RE: question for anyone who works on ctd
Instructions out of the shop manual....
REMOVAL
[ol][*]Disconnect both battery negative cables.[*]Raise vehicle on hoist.[*]Partially drain engine coolant into container suitable for re-use (Refer to 7 - COOLING - STANDARD PROCEDURE).[*]Lower vehicle.[*]Remove radiator upper hose.[*]Disconnect coolant recovery bottle from radiator filler neck and lift bottle off of fan shroud.[*]Disconnect windshield washer pump supply hose and electrical connections and lift washer bottle off of fan shroud.[*]Remove viscous fan/drive assembly. (Refer to 7 - COOLING/ENGINE/RADIATOR FAN - REMOVAL).[*]Remove cooling fan shroud and fan assembly from the vehicle.[*]Remove the accessory drive belt (Refer to 7 - COOLING/ACCESSORY DRIVE/DRIVE BELTS - REMOVAL).[*]Remove the cooling fan support/hub from the front of the engine.[*]Raise the vehicle on hoist.[*]Remove the crankshaft damper and speed indicator ring.[*]Remove power steering pump.[*]Remove accessory drive belt tensioner.[*]Remove the gear cover-to-housing bolts and gently pry the cover away from the housing, taking care not to mar the gasket surfaces. Remove crank seal dust shield with cover.[*]Support the cover on a flat work surface with wooden blocks (Removing Seal from Cover), and using a suitable punch and hammer, drive the old seal out of the cover from the back side of the cover to the front side(Removing Seal from Cover). [/ol]
Old Aug 25, 2007 | 08:33 PM
CowboyBob's Avatar
CowboyBob
It is more than likely your vacuum pump seal. I had a similar leak and it was the seal. Cost about $50-60 to fix. You can get a kit with a better seal at www.fixinrams.com. It has a video and includes the tools, seal, gaskets to fix it. Don't replace the pump because you'll get the same crappy seal.
Old Aug 26, 2007 | 09:14 AM
MCDiver's Avatar
MCDiver
Thanks for the link, I will have to get under the truck again and look at this . I like the site!!
Old Aug 27, 2007 | 12:23 PM
Mayfair's Avatar
Mayfair
It MAY just be the by-pass hose whereas that leak that you see is totally normal.
Old Sep 8, 2007 | 08:31 AM
MCDiver's Avatar
MCDiver
Replaced the vacuum pump seal, the kit is great great instuctions, nice parts. Even sends you the tool to do the job. Next is the front main seal, hope that stops all of the oil leaking once and for all. The pump no longer leaks though!!!
