Engine cutting out while towing
Old Aug 27, 2007 | 12:11 AM
fattommy's Avatar
fattommy
Default Engine cutting out while towing
Hey All, I was towing about 7K pounds the other day. I was heading up an incline ataround 25-30 mph running about 2300 rpm when all of a sudden the engine cut out for a second and then came back. I lost about 500 rpm's when it cut out and then returned to 2300 rpm. It did it twice on separate inclines and also did it under excelleration onaflat part of the highway with a load of about 5100 pounds a while back. Any ideas?
Thanks for any input...
-Tom
Old Aug 27, 2007 | 12:46 AM
Captain Squalus's Avatar
Captain Squalus
Default RE: Engine cutting out while towing
fuel filter
Old Aug 27, 2007 | 02:42 AM
firemansdodge's Avatar
firemansdodge
Could be your lift pump. If you have access to check your fuel pressure.
Old Aug 27, 2007 | 08:13 AM
CowboyBob's Avatar
CowboyBob
Did you get any fault codes? Did it blow white smoke when it stalled?
Old Aug 27, 2007 | 08:59 AM
fattommy's Avatar
fattommy
Cap'n - changed fuel filter about 5000 miles ago... could it still need changing already?
firemansdodge - thought it could be the lift pump, sounds like I should get some guages installed
cowboy - can I assume that if the engine light didn't come on that no codes were thrown? Did not notice any white smoke... but will look for it if it happens again.
-Tom
Old Aug 27, 2007 | 11:02 AM
Silverline's Avatar
Silverline
Its the lift pump. Mine just started doing it again (replaced it about 10k ago). You'll want to get it fixed soon or it can take out your injector pump too which is about a $1200 problem. Good luck.
Old Aug 27, 2007 | 11:55 AM
CowboyBob's Avatar
CowboyBob
You can have codes with no CEL. Try the 3 click method (turn the key on and off 3 times real fast, but don't start the engine) and see if there are any codes. They will be displayed in your odometer readout. Write them down and post here (if you have any).
Old Aug 27, 2007 | 04:08 PM
fattommy's Avatar
fattommy
yep, I got codes....
1693
0216
0217
--Tom
Old Aug 27, 2007 | 04:14 PM
fattommy's Avatar
fattommy
Yep, definitely lift pump by those codes... but I can still drive the truck so can I assume that the vp44 isn't dead... yet?
-Tom
Old Aug 27, 2007 | 04:52 PM
Kev_n_AZ's Avatar
Kev_n_AZ
not cheap...
http://www.mwfi.com/VP44.htm
I just picked up my fi pump from them for my 93..shippin is included !
