still broke
Old Sep 7, 2007 | 02:38 PM
kg1687's Avatar
kg1687
Default still broke
Found out how much the part is. Dodge is charging 455 dollars and I'm going through an online oem site and they're offering it at 371.25 I thought it would be closer to 200 but at least I'll be able to finish it. up b4 long. I'm also gonna drop a BD Power lift pump in due to the lack of funds I have right now. Just had eyesurgery.
Take it easy guys.
Old Sep 7, 2007 | 03:40 PM
Drew's Avatar
Drew
Default RE: still broke
so she's still acting funny since you tried to swim.
Old Sep 8, 2007 | 05:46 AM
kg1687's Avatar
kg1687
Well I havne't had the money to buy the part I took it in to get it I was still imagining the cheap 200 dollar fix. Then they're all it'll be about 550 dollars i'm like ok I'll catch ya later. and left. Because i didn't have the money but I can get it for like 347 from http://www.trademotion.com/partlocat...?siteid=214650then dodge will throw it in for 30 bucks. Then I was thinking bout buying a bd lift pump because i wont' have the money to buy a fass right off the bat and that way I wont worry so much about my injector pump.Then It should be all ok. For a bit. Also buying some ams oil. for everything.... Just to double check everythings cleaned out then also gotta buy a seal for my axle shaft.
Old Sep 8, 2007 | 08:12 AM
Silverline's Avatar
Silverline
From what I've heard BD pumps are pretty much Carter pumps. If you're looking for something less expensive I'd go with a Walbro or a Aeromotive. I've got an Aero and it was running great until I dropped it and killed the internals.
