I wonder...
Old Sep 7, 2007 | 09:38 PM
jakebrake's Avatar
jakebrake
Default RE: I wonder...
To be honest steve, I don't use any of them
Old Sep 7, 2007 | 09:41 PM
steve05ram360's Avatar
steve05ram360
ORIGINAL: jimmydaleo
ORIGINAL: steve05ram360
I use them. the front shaft lube point.....Brakes, I already knew, but a lot of people did not. the fuel filter I used. Keep them coming as they are great. if you have the 48re and want to do a shift kit install diy feel free to
well, I already have the kit installed and it's under the tranny warranty when I got my tranny rebuilt. Otherwise I'd do it. If there were someone local who wanted it doneI'd be happy to give it a shot, it cannot be that hard.
I dont think it is... you should however check this page out in the '05 service manual for VB adjustments... 7276, the throttle pressure adjustment gap needs to be 5/8" of an inch otherwise you'll have funny shifting. the other adjustment requires gauges.
It can not be too hard. I am going to give it a try probably in January. I will get pics and all info and maybe try a diy of my own if it all works out well.
Old Sep 7, 2007 | 09:46 PM
gtxpooch's Avatar
gtxpooch
I use them. I know that if I hadn't,I would have spent a lot more money than if I hadn't! Keep them cummins
Old Sep 7, 2007 | 09:54 PM
steve05ram360
ORIGINAL: jakebrake
I'd have thought you'd be writing them...
Old Sep 7, 2007 | 10:26 PM
jakebrake's Avatar
jakebrake
It's a dodge with a cummins powerplant, I never have to work on it
Old Sep 7, 2007 | 10:30 PM
UpBranchLiner's Avatar
UpBranchLiner
Im a pro at screwing stuff up all by myself, so yes i use them. (fuel filter/lube point helpful hints)
Old Sep 8, 2007 | 09:43 AM
cujo's Avatar
cujo
Within the first couple of days after joining this form I read almost all the DIY's top to bottom. Losts of good info here. I'm one of those people that hate trusting my truck to someone else. If I'm capable of doing it then I'll do it. With that said I also know where to draw the line with a job I am not comfortable with. The DIY's are great tools.
Old Sep 9, 2007 | 01:28 PM
ga_noplugs's Avatar
ga_noplugs
ORIGINAL: cujo
I agree about trusting other folksw. I also like the DIY's.
Heck, Jake even help convinced me I could remove a snapped bolt from my differential. (thanks Jake)
Who knows what that saved but it only cost me 9 bucks and 15 minutes to fix myself.
Old Sep 9, 2007 | 02:29 PM
jakebrake's Avatar
jakebrake
No problem.Just ya get yourself a really good extractor set.
this is what I got at work
http://buy1.snapon.com/catalog/item....mp;dir=catalog
or for the weekend mechanic
Old Sep 9, 2007 | 03:21 PM
ga_noplugs's Avatar
ga_noplugs
ORIGINAL: jakebrake
No problem. Just ya get yourself a really good extractor set.
http://buy1.snapon.com/catalog/item....re&dir=catalog
Whew. That first one is pricey but if you do it for a living I guess its not bad.
If I start snapping more bolts I'll look at the 2nd one (and replace the Torque wrench too ... )
