reverse lights
Old Sep 11, 2007 | 01:41 PM
bigmike's Avatar
bigmike
Default reverse lights
So my reverse lights quit working last night. I checked the fuse and it is ok. I didn't check the bulbs 'cuz i figured what are the chances of them both going out at the same time. I figure there must be a relay or a switch on the tranny, but don't really know. Anybody got any ideas?? I'll check to see if there are any obvious bare wires that may cause a short.
Old Sep 11, 2007 | 10:25 PM
CowboyBob's Avatar
CowboyBob
Default RE: reverse lights
What chu talkin bout Willis! Check them *****..... I mean bulbs.
Old Sep 11, 2007 | 10:37 PM
RobertDunn's Avatar
RobertDunn
Check the electrical ground...? A buddy of mine who was a Mechanic would have the rear ends go out in his Chevy trucks, the entire thing at once, it was always the eletrical ground... no idea if they even use that system anymore...
Old Sep 11, 2007 | 10:51 PM
DAGS's Avatar
DAGS
I had a 2000 dakota before my ram and the backup lights stopped working when it was still under warrenty and it was the switch in the tranny. dealer fixed.. shortly after warrenty was up they stoped again. i talked too a buddy of mine who is a dodge mechanic and he said it is a bitch of a job the tranny needs to come out and the whole valve body too. so I never fixed .. I sold the truck about a year later.
Old Sep 11, 2007 | 11:04 PM
Kev_n_AZ's Avatar
Kev_n_AZ
bigmike....is your truckstill under warranty?
Old Sep 11, 2007 | 11:22 PM
MarkRAM01's Avatar
MarkRAM01
It happened to me about a year ago took it in under warranty and there is some reverse switch or relaythat had to be replaced in the manual transmission if you have one.
Old Sep 12, 2007 | 02:13 PM
bigmike's Avatar
bigmike
thanks guys. No, i am not under warranty anymore. I looked in my CHilton's manual about that reverse switch on the tranny and they make it sound like i should be able to reach it easily, since it is mounteed on the side of the tranny. I won't have chance to get to it until this weekend, but i will keep everyone posted.
I will also check them *****...i mean bulbs.
Old Sep 12, 2007 | 03:13 PM
RyEnFF31's Avatar
RyEnFF31
With both going out at the same time I would have to agree it sounds like the switch in the tranny. I did have problems with my '06. The tail light circuit board craped out on me, but it was only the passanger side, and it was under warranty.
Old Sep 12, 2007 | 10:21 PM
FroneDaddy's Avatar
FroneDaddy
Same problem here, replaced the tranny switch and still doesn't work. I ended up running a hot wire to the switch and then to the lights and now they work fine.
