Buying a Diesel
Old Sep 14, 2007 | 10:30 AM
lil73duster's Avatar
lil73duster
Default Buying a Diesel
Anything specific I should look for when I'm looking at a diesel??
its a 1998 1/2 Dodge Ram
180,xxx miles
Stacks
Chipped
it's sitting on 33s
I think it was a extended cab (can't exactly remember).
Old Sep 14, 2007 | 10:36 AM
mopar98's Avatar
mopar98
Default RE: Buying a Diesel
Well chief it ain't a 1/2 ton .
and yes there are things to look for.
Check up top of the page and you'll see the stickies.
Lots of info there.
Old Sep 14, 2007 | 11:10 AM
CutterW's Avatar
CutterW
I think he might mean its a 98.5 so its a 24V
Old Sep 16, 2007 | 06:54 AM
MN Cummins Lvr's Avatar
MN Cummins Lvr
First thing to watch for if it's a 98 1/2, is to make sure it doesn't have a "53 block." On the drivers side, crawl underneath and a large 53 is stamped on the block. These blocks are prone to cracking problems. Also, if this engine is modified, at very minimum, should have EGT and fuel pressure gauges. If truck has an automatic tranny, find out when/who rebuilt it. If it has a 5 speed, ask about the 5th gear nut falling off and if 5th gear was replaced with a fully splined shaft. Hope this helps!
Paul
Old Sep 16, 2007 | 03:54 PM
Drew's Avatar
Drew
53's didnt start untill '99 and ran through 01.
the 5th gear nut is a good point. . .also look to see if the lift pump has ever been replaced, if it has with what, and if the VP44 was also replaced.
