Pre or Post Turbo?
Old Sep 16, 2007 | 10:42 PM
steve05ram360's Avatar
steve05ram360
Default RE: Pre or Post Turbo?
I'd go pre turbo... gives a better idea of what the motor is seeing. If you already know the post turbo #'s are cooler and your letting your preturbo temp drop to 300~320 (320 is my setting) then post turbo temps should be more than cool enough. if your check the flash point of the oil your using, you will know at what temp coking can start at... the higher the flashpoint the better. synthetics dont have a coking problem associated with them and are preferred for turbo applications for that reason...
Old Sep 16, 2007 | 10:43 PM
steve05ram360
Old Sep 17, 2007 | 08:35 AM
CowboyBob's Avatar
CowboyBob
Get an extra EGT probe and a toggle switch. You can have the best of both worlds. You can get a probe for around $30 and a switch for $5.
