Transmission fluid temp question
Old Sep 26, 2007 | 12:42 PM
Twoforme2's Avatar
Twoforme2
Default RE: Transmission fluid temp question
ORIGINAL: steve05ram360
do you guys have a link to the tranny line adapter? I'd like to add it to the Info thread at the top.
For the 2nd Gen
http://www.dieselmanor.com/dm_products/DM-CLG2.asp
For the 3rd Gen
http://www.dieselmanor.com/dm_products/DM-CLG3.asp
Old Sep 26, 2007 | 01:52 PM
steve05ram360's Avatar
steve05ram360
awesome, thanks
Old Sep 26, 2007 | 02:21 PM
salty's Avatar
salty
that adaptor is a perfect fit
Old Sep 26, 2007 | 09:06 PM
Twoforme2's Avatar
Twoforme2
quick note...DON'T be laying directly under it, when you loosen the factory one to remove it...Not that I did that, I would never do something as stupid as that....Quick note number 2...Tranny fluid does not smell like aftershave, no matter how hard you try to convince the wife.
Old Sep 27, 2007 | 12:54 AM
cracker's Avatar
cracker
My 06' reads around 170- 185 just normal driving. I have seen 200 when towing in the hills. This reading from the edge attitude monitor that gets it from the computer. Not sure where the pick up is.
Old Sep 27, 2007 | 08:33 AM
NCcummins's Avatar
NCcummins
drew,
i just installed all the edge juice with attitude senoirs, but the one I havent put in yet is the tranny temp. because you have the change the fluid and everything after u put it in and i just change it a lil while ago.
should i just leave it any not install it untill i need another fluid change, or should i install asap with the edge?
Old Sep 27, 2007 | 09:48 AM
Twoforme2's Avatar
Twoforme2
Why would you have to change the fluid to put in the sensor?
Old Sep 27, 2007 | 10:15 AM
finny's Avatar
finny
i think he has the deep pan if i am not mistaken and inorder to put thesensor in you have to take off the pan. just a hypothosis
Old Sep 27, 2007 | 12:11 PM
salty's Avatar
salty
just a quick update.. I have been driving the truck for a couple days now.. I have not seen the temp go above 150ish... it goes back down quikly at stop signs and such... Guess I will have to hook up the 37' fifth wheel RV and see how she goes..
Old Sep 27, 2007 | 01:13 PM
Drew's Avatar
Drew
ORIGINAL: NCcummins
drew,
depends on the placement of the pickup. . .is it one that goes in the pan, then yea, you'll need to dump the oil. . .however if it is taking temp in one of the cooling lines you shouldnt have to.
