throttle stickin
Old Sep 28, 2007 | 01:13 AM
Kev_n_AZ's Avatar
Kev_n_AZ
Default throttle stickin
ok guys and gals.
I realize that I may be the sole owner of a first gen cummins here, but has anyone else exprienced their throttle pedal stickin in place and no goin down? on a couple occasions, I hit the trottle pedal and its like tryin to kick a block wall. it doesnt move!! after a few swift "re-adjustments" it gives in to sheer force. I am concerned maybe the cable or linkage may be fouled in some way.
any ideas would be much appreciated .
thanks
Old Sep 28, 2007 | 07:21 AM
Drew's Avatar
Drew
Default RE: throttle stickin
sounds like your linkage to your VE is either 1. binding up, or 2. the throttle arm on the VE is comeing up too high.
if #2, all you need to do is losten the jamb nut and move the arm down a few teeth.
Old Sep 28, 2007 | 12:26 PM
Mayfair's Avatar
Mayfair
Demon is also a 1st gen owner, however he's probably still down for the count with his surgery.
Your on your own son ...
Old Sep 28, 2007 | 01:18 PM
Drew's Avatar
Drew
ORIGINAL: Mayfair
BBBBZZZZZZZZZZZZZZZZZZTTTTTTTTTTTT
sorry, you are wrong. . . 2nd gen
95 or 97 vintage I believe
Old Sep 28, 2007 | 01:26 PM
Mayfair's Avatar
Mayfair
DAMN, that's right. He's a 12v owner. That's what I was thinking of.
Old Sep 28, 2007 | 01:30 PM
olddodge's Avatar
olddodge
I have an '89 no problems w/the throttle,161,000mi
Old Sep 28, 2007 | 01:39 PM
Drew's Avatar
Drew
Kevin just replaced his VE pump not long ago. . .I can understand it needing a few more adjustements to get everything right.
Old Sep 28, 2007 | 02:03 PM
92oilburner's Avatar
92oilburner
I have a 92 dually, with 169,000. I have owned it for 4 years now, withno throttle problems.
Old Sep 28, 2007 | 03:46 PM
Kev_n_AZ's Avatar
Kev_n_AZ
I am not sure if the throttle stuck before the fi pump was replaced. I know its done this twice in a month and its freaky when youre in an intersetion and you cant goooooo!
I will update after I figure it out.
thanks guys!
