oil pressure at startup
Old Sep 29, 2007 | 07:58 AM
hohner's Avatar
hohner
Default oil pressure at startup
What is a normal amount of time for the oil pressure gauge to come up on start up? My '99 CTD takes a count of 3 before the needle pops up...it does not matter if it is hot or cold...same 1,2,3,,,pressure. Changing oil and filter did not change anything either. I know I should be worried that the motor will eat up the main & rod bearings due to this but is it normal or not for the Cummins engine?
Old Sep 29, 2007 | 10:34 AM
SkyboltAl's Avatar
SkyboltAl
Default RE: oil pressure at startup
I've had my 24v Cummins for 9 years now (98.5) with 130,000 mi. The oil pressure lag is normal.
Old Sep 29, 2007 | 11:06 AM
hohner's Avatar
hohner
Thanks, Skyboltal.
Old Sep 29, 2007 | 01:13 PM
BFR's Avatar
BFR
i really dont think its an actaull oil pressure lag (mine does the same thing) i think it is more of a sensor lag but thats just me
Old Sep 29, 2007 | 02:06 PM
Drew's Avatar
Drew
that sensor looks for a minimum of 5psi. once the 5psi has been established the computer sends a signal to the gage to move. as you see your engine RPM's come up you also see the pressure. . .however this is once again the computer since the pressure 'switch' has satisfied the 5psi need the computer wants to see.
the 12 valve guys I believe the gage was a true indication of pressure. us electronic guys only have a computer model.
