Chips/ programers and tunners what best
Old Oct 6, 2007 | 01:19 PM
memphisii's Avatar
memphisii
Default Chips/ programers and tunners what best
SoI have searched a bunch and im trying to decire what chip,programer,tunner is best and why you think why i dont realy want to use a flash programer but let me know what you all think is the best any why please thanks, btw i have a 06 3500 6-speed manual
Old Oct 6, 2007 | 01:26 PM
simonsj's Avatar
simonsj
Default RE: Chips/ programers and tunners what best
I was just about to post the same question. I have a 2001Dodge Ram Diesel 2500Automatic with 220K.
Any idea's??? I am looking for towing/passing power.
Old Oct 6, 2007 | 02:38 PM
Drew's Avatar
Drew
well it all depends on what you want to do with your truck. . .hot rodding, just a boost in performance, or what. . .there are alot out there, edge, quadzilla, TST, Van Aaken. . . .
one warning though, if your truck was produced after 6/06 you cannot use the TST box. . .they are still working on a fix.
Simon. . .since you are wanting more towing/passing power there are alot out there for you too. . .if you want to go with the downloader, Smarty is probably the best, for boxes, I would probably go with an edge box.
Old Oct 6, 2007 | 03:25 PM
NCcummins's Avatar
NCcummins
i agree with drew...i like my edge alot though!
Old Oct 6, 2007 | 03:53 PM
memphisii's Avatar
memphisii
im going for mostly towing, some eceonomy when im not in the throttle and performance too not doing much hot rodding, i was leaning toward the edge chip and just wanted to see if there was any thing better,
o ya does any one know how much power a stock clutch will hold before it starts to slip thanks
Old Oct 6, 2007 | 04:09 PM
Drew's Avatar
Drew
if you look in my sig, the clutch on my NV5600 was able to keep up with that power. . .however she was slipping hard. . .anything above 100hp and the stockers gunna let go.
BTW, with my TST set to 0/0 I got 285hp and 560tq
since you have an 06, I beleive the clutch and DMF* you have can handle about the same. . .but I wouldnt venture above 75hp due to the DMF and it's track record with not being able to handle high HP.
*DMF, Dual Mass Flywheel, basicaly was installed more for creature comforts and to keep alot of the jerkyness of the engine to a minimum.
Old Oct 7, 2007 | 12:09 AM
memphisii's Avatar
memphisii
thanks for the info drew
Old Oct 7, 2007 | 02:07 AM
tonyslaramie's Avatar
tonyslaramie
Is there a resource, website, publication where one could research how each of these performance manufactuers are making power and the pros versus cons of the different power making tecniques? Chip vs. Downloader, fuel vs. timing, stacking, safe thresholds. The manufacturer's websites seem end-user friendly, while I'm interested in the technical side of things.
Old Oct 7, 2007 | 10:50 AM
Bigriver's Avatar
Bigriver
Another advantage I like about my Edge Juice/ Attitude, is that it will read and erase any codes that may happen to pop up on you. Of course, there are other features it has and I am satisfied with the performance I find with it. I'm not into the hot roddin, just like to romp on it now and then.
Old Oct 7, 2007 | 01:01 PM
Twoforme2's Avatar
Twoforme2
ORIGINAL: tonyslaramie
Unfortunately, no...you will have to spend hours upon hours of research on line, or spend thousand upon thousands to find out for yourself...However if you have a particular one in mind, someone may be able to answer for you how it works.
