6.7L Fuel Filter Draining [PIC]
Old Oct 7, 2007 | 11:18 AM
sabersix's Avatar
sabersix
Default 6.7L Fuel Filter Draining [PIC]
I finally got around to draining my fuel filter at 5800 miles. The 6.7L Cummins has a different fuel filter than the 5.9L and is drained differently. The star-shaped stopcock must be opened a couple of turns (don't unscrew too far or it will come out completely). Little or no fuel will drain out until you turn the ignition on (but don't start) for a few seconds to energize the lift pump. I placed a mason jar on top of my differential to catch the fuel. No water was present in my fuel.[hr]
Old Oct 7, 2007 | 04:09 PM
Joel_MD's Avatar
Joel_MD
Default RE: 6.7L Fuel Filter Draining [PIC]
Thanks for the tip, Colonel. I tried opening mine when I changed the oil, and only a little bit dribbled out. I guess I should have read the manual!
Old Oct 7, 2007 | 04:52 PM
sabersix's Avatar
sabersix
ORIGINAL: Joel_MD
That's the thing, it wasn't in the manual. Just said drain the fuel filter regularly. I was like you. At first only a little dribbled out. I'm thinking WTF?!? Then I tried a couple of seconds with the ignition switch on and the valve open. Bingo!
Old Oct 7, 2007 | 10:17 PM
sanddragonslayer's Avatar
sanddragonslayer
thanks that will come in handy!!
