leveling kit questions
Old Oct 8, 2007 | 10:50 AM
memphisii's Avatar
memphisii
Default leveling kit questions
so my buddy got a leveling kit installed at les schwabs and they had to adda shim to help it from pulling does any one know what shim they may have added or if its an adjustable ball joint or what? thanks
Old Oct 8, 2007 | 02:57 PM
tdmopar59's Avatar
tdmopar59
Default RE: leveling kit questions
thats wierd.... adding a shim? normally its just two coil spacers.. any aligning would be like a normal alignment on the rack..
Old Oct 8, 2007 | 03:06 PM
memphisii's Avatar
memphisii
but on some vehciel you can not adjust camber and caster. he was told that they have has a bunch of the rams and fords with 35's and a leveling kit pull to the left i believe it is.
Old Oct 8, 2007 | 07:38 PM
Erock509's Avatar
Erock509
I dealt with same thing with my last truck and now my current one. Never heard of a shim, but on my last truck I only had 33's and the pull was still bad after an alignment, the tech told me that he could get the truck within specs and it would still not change the pull due to the tires. The only thing they can really adjust to any degree is the toe, so you can get even wear, which my truck now, is in bad need of. The only thing that was recommended was an after market ball joint on which ever side the needed the adjusting, and the price was reasonable just never did it. So thats next on my list, balance, rotation, and alignment, I'll see if I have to do the am ball joint.
