Anyone know what this means??
Old Oct 12, 2007 | 01:50 PM
  #21
Drew's Avatar
Drew
Default RE: Anyone know what this means??
ATF +4 is synthetic
the manual tranny is "supposed" to be maintenance free. . .but I change mine out ever 30K wether it needs it or not. the NV5600 is VERY picky when it comes to fluids. AMSoil makes a 5w-30 MTF that is designed just for the NV5600. pensoil syncromesh is also made for it. I have the amsoil in mine and I noticed better shifting and less noise right off the bat.
if you use the wrong fluid in the NV5600 the bearings will sieze up and the syncro's will prematurely wear out. even those that put in 75-90 had bearing issues and the syncro's crack on them.
Old Oct 12, 2007 | 02:19 PM
  #22
FroneDaddy's Avatar
FroneDaddy
I just went outside to check the tranny fluid, where is the dipstick?
Old Oct 12, 2007 | 02:22 PM
  #23
Drew's Avatar
Drew
no dipstick. . .you just need to remove the fill bolt and make sure the fluid is level with it. I cannot remember the size of the allen head off the top of my head.
if you do want to change the fluid pull one of the bottom PTO cover bolts out and let the fluid drain out from there. put the bolt back in and fill. I actualy filled mine through one of the higher PTO cover bolts and put in 5 quarts to make sure the front bearings get some lube.
Old Oct 12, 2007 | 02:51 PM
  #24
FroneDaddy's Avatar
FroneDaddy
ok, now to another question, where is the pto cover..............and is this the same kind of pto like on a tractor, can we hook stuff up to it
Old Oct 12, 2007 | 02:55 PM
  #25
Drew's Avatar
Drew
yup. . .all you need to do is look at the side of the tranny and you'll see it heald in by 6 bolts.
Old Oct 12, 2007 | 02:57 PM
  #26
FroneDaddy's Avatar
FroneDaddy
Really, what do people hook up to them on a pickup................once again thanks for all the help!!
Old Oct 12, 2007 | 03:02 PM
  #27
Drew's Avatar
Drew
hydraulic pumps for farm empliments, winches, and so on.
Old Oct 12, 2007 | 03:08 PM
  #28
FroneDaddy's Avatar
FroneDaddy
I've never seen anyone use a pto on a pickup
