valve addjustment
Old Oct 9, 2007 | 05:21 PM
NCcummins's Avatar
NCcummins
Default valve addjustment
got the valve cover off putting in new injectors and want to adjust my valves while im under it and got the cover off..
drew or jake or someone...what are the valves supposed to be addjusted too??
thanks!
Old Oct 9, 2007 | 05:36 PM
NCcummins's Avatar
NCcummins
Default RE: valve addjustment
https://dodgeforum.com/m_910497/tm.htm
found the DIY...
haha thanks!
Old Oct 9, 2007 | 06:52 PM
jakebrake's Avatar
jakebrake
The easiest way is to pull the breather element off the front cover (It's threaded and twist off after you pull the tube off of it) If you look in there with a mirror, you can see the tdc mark on the gear and cover. Line them up, then mark your balanccer to the front cover (use a paint pen or white out, ect) because that mark is for tdcc#1. after myou've adjusted the valves, roll the engine over to your paint mark and do the other set of valves.
Old Oct 9, 2007 | 08:18 PM
steve05ram360's Avatar
steve05ram360
are the specs the same for his motor? You should download the 2nd gen manual and verify... it's for a 2001 but should have the same motor as your truck IIRC.
Old Oct 9, 2007 | 08:42 PM
NCcummins's Avatar
NCcummins
well, after fighting with the injectors and getting to the very back one for a while...i decided i would save the adjustment for a later date. But it would be good to know if mine is suppost to b the same....I is .010 and E is .020 ??? if not i guess i need to look for it. Or find a DIY for my 2002 model.
Thanks!
Old Oct 9, 2007 | 09:34 PM
jakebrake's Avatar
jakebrake
Intake is .010 and exhaust is .020. If you look on your engine data plate on the driverside of the front cover, it'll have the spec on it
Old Oct 10, 2007 | 08:23 AM
NCcummins's Avatar
NCcummins
thanks man!
Old Oct 10, 2007 | 08:58 AM
Drew's Avatar
Drew
all of our engines will be the same when it comes to lashing the valves and the order. only difference is the valving.
Old Oct 10, 2007 | 09:00 AM
NCcummins's Avatar
NCcummins
alright nice....
i felt like a retard yesterday..i called the guys a diesel dynamics and told them i cant find where the injectors are..had no idea they where under the valve cover...had to explain to them i was a virgin at this...hahaha
Old Oct 10, 2007 | 12:20 PM
blondeguy08's Avatar
blondeguy08
whats the purpose of a vavle adjustment?
