Diesel Dynamic Injectors!
Old Oct 10, 2007 | 12:59 PM
R0oster31's Avatar
R0oster31
Default RE: Diesel Dynamic Injectors!
Smoke...
Old Oct 10, 2007 | 01:28 PM
Drew's Avatar
Drew
ORIGINAL: R0oster31
Smoke...
and that you will with 100's. . .if you tow occasionaly, and still want good mileage and power increase I would not go above 50hp. 25-50hp sticks would fit you nicely. then put in an edge box or a downloader and your set to smoke the tires straight off the rims.
one thing you have to remember is your stock fuel system can only handle a max of 100hp before you run your VP44 dry, and you also render your turbo inefficient.
Old Oct 10, 2007 | 03:01 PM
blondeguy08's Avatar
blondeguy08
so would stage two be a safer choice than stage 3? or should i get stage 3 and baby it untill i get a good fuel system?
Old Oct 10, 2007 | 03:05 PM
steve05ram360's Avatar
steve05ram360
with what you mentioned above... any injector up to 50HP will work for you. go bigger and kiss your mileage good bye. the fuel system will work as is... when you do upgrade, Walbro or FASS is the way to go.
Old Oct 10, 2007 | 03:07 PM
blondeguy08
well darn...... lol ..... edge jammers even at stage three advertise better fuel mileage... I just would like a lot of power on the tap if ya know what i mean? I have a bully dog. my friend just got stage 3 nozzles and he loves them ... thanks
Old Oct 10, 2007 | 03:28 PM
NCcummins's Avatar
NCcummins
im telling you that after u put injectors in..you are not going to be easy on it all the time...even on stock level 0 mine smokes like crazy and can tell the difference...it will stay side ways for as longs as i want it to on dry pavement
Old Oct 10, 2007 | 04:29 PM
Mayfair's Avatar
Mayfair
LA LA LA LA LA LA LA ..... I can't HEAR YOU !!
I don't wanna even THINK about installing injectors now !!
( Chris, did you take pics of the install for our write up section? )
