pump relocation
Old Oct 24, 2007 | 11:50 AM
Drew's Avatar
Drew
Default RE: pump relocation
I thought it was up there in the FAQ. . .it is now
Old Oct 24, 2007 | 12:09 PM
Mayfair's Avatar
Mayfair
Old Oct 24, 2007 | 12:33 PM
Drew's Avatar
Drew
hum. . . .now websence is blocking comcast [:@]
Old Oct 24, 2007 | 04:19 PM
CowboyBob's Avatar
CowboyBob
I built a prototype board for the electronics and have talked myself into spending enough money to actually put the second Walbro pump on the system. Now that my shooting season is over, I am going to start working on phase 2. Second Walbro and fail over ciruit!!! This will complete the project and get it the way I originally wanted it. If I can find a used sending unit that does not have the in-tank pump, then I will drop the tank and get rid of that pos in-tank system for good!
Old Oct 24, 2007 | 04:28 PM
roadking096's Avatar
roadking096
http://www.cowboyplayground.com/public/dp.htm
HeyBob, did you ever figure a way touse that backloading feature on your regulator? If not,maybe since a diesel's vacuum does'nt vary with engine load, you could tap the turbo pressure and send it to the opposite side of the diaphram. Not an engineer, just a thought.
