b100 in a 2005 5.9
Old Oct 26, 2007 | 04:20 PM
JimmyDiablo's Avatar
JimmyDiablo
Default b100 in a 2005 5.9
Why is it that I am not supposed to run b100 in the truck? I don't ubnderstand.
Old Oct 26, 2007 | 04:22 PM
lilfroger's Avatar
lilfroger
Default RE: b100 in a 2005 5.9
'cause Cummins says not to
Old Oct 26, 2007 | 04:31 PM
JimmyDiablo
Why???????
Old Oct 26, 2007 | 04:34 PM
brunner's Avatar
brunner
because ASTM (gov't) has figured out a way to test it and come up with guidlines to make sure it is all the same. Or something like that. On edit: I am talking about 100% soybean oil, not waste oil or anything like that.
Old Oct 26, 2007 | 04:38 PM
cujo's Avatar
cujo
My guess is because they haven't done some silly-assed study to determine the long term affects. I know some guys who get the waste oil from eating establishments and brew/refine it to be B100 and have been driving on it for a while, mostly in smaller diesel engines. Just don't have the ***** myself to run in through mine.
Old Oct 26, 2007 | 04:47 PM
JimmyDiablo
If I can get the oil, I am going for it
Old Oct 26, 2007 | 04:52 PM
NickBeek's Avatar
NickBeek
The reason it has not been approved at the B100 level is because there are not the same quality controls in place epecially for home brew. If it's made right it will be fine. Cut corners and you will be sorry. BTW B100 will gel at a higher temp than #1 or #2 diesel, take this into account when you are in cooler climates.
Old Oct 26, 2007 | 04:57 PM
JimmyDiablo
Thank goodness I line in Phoenix Az. What is cool weather?
Old Oct 26, 2007 | 05:00 PM
cujo's Avatar
cujo
I'm guessing you could adjust the blend for colder weather or just use an Anti-gel?
Old Oct 26, 2007 | 05:18 PM
CowboyBob's Avatar
CowboyBob
I'd strongly suggest upgrading your fuel pump to a Walbro or FASS before running B100. I have been running B20 for a while and even attempted to make my own home brew for a while. The B100 is thicker than regular diesel. If you are using the stock lift pump, you are just asking for trouble.
Getting the oil is going to be the hardest part, at least it is around this part of the US. Most restaurants already have contracts with companies that come and take the oil away with big trucks and a big pump. They are not going to fool with individuals that want to put a barrel out back and have them fill it up.
