well whats different
Old Nov 8, 2007 | 11:18 AM
  #21
Mayfair's Avatar
Mayfair
Default RE: well whats different
ORIGINAL: woligator
there is a small rubber line that go from the turbine housing to a little pot on ur turbo,this is the wastegate actuator,the line is about 8' long u cant miss it,just unplug the actuator side and plug it whit a screw
so this way ull be able to return to stock if u want to
I don't know if you want to TOTALLY close it up.
When I got my Edge, it came with a new fitting to screw into that port that now has a small hole in it instead of the about 1/4" hole that was in there.
Old Nov 8, 2007 | 11:43 AM
  #22
blondeguy08's Avatar
blondeguy08
get a boost elbow.. its like 20$ on ebay and increased my boost from 24psi to 38 psi... cheap mod.... DO NOT PLUG IT...... it will cause major problems if you ever push it hard......
Old Nov 9, 2007 | 12:10 AM
  #23
02cummins's Avatar
02cummins
i will try that, thanks guys...cant wait till my lift is in this weekend though, im like a little kid on xmas eve
Old Nov 9, 2007 | 12:39 AM
  #24
jakebrake's Avatar
jakebrake
The autos are a metal line wastegateso the boost elbow won't work on those turbos. Edge has a bress plug you put in the line, you might wanna give them a call. If you have a manual you will have a rubber hose running to the wastegate so you can use the elbow on it
Old Nov 9, 2007 | 07:14 AM
  #25
woligator's Avatar
woligator
i dont think that even plugged problems can arise,the stock turbo will surge around 35psi
and at that point u heating the air alot,its way pass its effiecient point
Old Nov 9, 2007 | 09:15 AM
  #26
02cummins's Avatar
02cummins
well i see bd has a waste gate kit with the nut you can adjust to where u want the waste gate to kick off at, but its 160$ i would rather do the plug with a hole in it or something, haha but ill read up on it more tonight, and something will be ordered!
