crank sensor
Old Nov 17, 2007 | 07:38 AM
thehedonist's Avatar
thehedonist
Default crank sensor
I posted a while ago about my truck shifting back and forth between 3rd and overdrive when driving at around 45 mph. All of the responses I got led to a bad ground. I took my truck in to the mechanic and he is trying to tell me I need a new crank sensor. I have never heard of this part. He also said that is the reason the truck makes a clunk or a ping noise when shifting into reverse. Has anybody heard of this part? Where is it located and how easy is it to fix. The mechanic is telling me $700 to fix this thing.
Old Nov 17, 2007 | 07:40 AM
thehedonist
Default RE: crank sensor
Oh ya, my truck is a 98.5, 24 valve with an auto transmission.
Old Nov 17, 2007 | 11:14 AM
behindbars's Avatar
behindbars
Try this link. I think this is what you're looking for.
http://www.dodge-diesel.org/articles/cps/ckp.htm
Old Nov 17, 2007 | 11:25 AM
Parts/Service's Avatar
Parts/Service
I would find a second opinion. The crankshaft position sensor (part # 5015488AA) retails for $93.00. And is a fairly easy change. I don't see the crank sensor having anything to do with the problems that you have. If the crank sensor was "bad" it should set a diag code. You should check the battery ground.
Old Nov 17, 2007 | 09:03 PM
jakebrake's Avatar
jakebrake
The noise going into reverse is most likely a ujoint. I would change them all out seeing as its only $50 to do all three on the rear driveline. And that shifting problem is still probably a bad ground. If you have a few simple tools you can fix all of these yourself in less then a day and save some money.
Old Nov 21, 2007 | 07:49 PM
thehedonist
The U-joints are all tight. Any other ideas?
Old Nov 21, 2007 | 07:55 PM
Kev_n_AZ's Avatar
Kev_n_AZ
ORIGINAL: thehedonist
tight as in "bolted down" tight or "they have no play and do not chatter" tight????
U joints need to be checked for play and chatter.
Old Nov 26, 2007 | 04:47 PM
thehedonist
According to the mechanic, the u-joints are fine. But then again, he did try to tell me that I needed a crank sensor. Seems weird. I did get under the truck myself and try to move the drive shaft around to listen for play in the u-joints. They did not seem to move to me.
Old Nov 26, 2007 | 05:24 PM
Mayfair's Avatar
Mayfair
Is your truck still hunting for gears?
Have you cleaned up your grounds?
Old Jan 20, 2009 | 12:44 AM
thehedonist
I had my transmission filter cleaned out and holy ****, things are working normal again. Problem solved.
