toyo open country at
Old Nov 22, 2007 | 01:05 AM
  #21
Aero Ram's Avatar
Aero Ram
Default RE: toyo open country at
ORIGINAL: steve05ram360
325-60-18's... 33's 13.5" wide
and a 2" level kit it looks like? whats you mpg?
Old Nov 22, 2007 | 08:55 AM
  #22
steve05ram360's Avatar
steve05ram360
2.5" skyjacker D25 springs up front, lorenz leaf pack in the rear, approx .5" of lift in the rear.
https://dodgeforum.com/m_1037052/tm.htm
best mileage has been 19.0 if your concerned about mileage, look for a light weight wheel that is strong and a tire that is less than 65 lbs... my wheel tire setup = 105 lbs each corner and I'm sure that is not helping mileage. if it were a lighter setup, throttle response would be better and so would mileage.
Old Nov 22, 2007 | 09:15 AM
  #23
FroneDaddy's Avatar
FroneDaddy
I have a set of Cooper 285/75/17's, pretty aggressive tread with 3.73's and I get 18 mpg, half highway, half city.
Old Nov 23, 2007 | 04:07 AM
  #24
Aero Ram's Avatar
Aero Ram
Alright thanks guys, never thought about the wheel and tire weights...good call
steve if you gotta pic of your truck from the side I'd like to see it so I can check out the stance...I'm stuck between a 2" level or a 4.5" lift...I just wanna run some 35/12.50s so I can get a better footprint in the sand....trucks like to sink to the frame and when you got the bigger truck of the bunch it gets hard to find someone to pull ya out...lol
P.S. my driveway is sand at the momment...don't ask
Old Nov 23, 2007 | 10:58 AM
  #25
steve05ram360
here's a pic that I have on my laptop... I can post more when I get home...
[IMG]local://upfiles/1508/5FD7939BC0A94691824AFED7D02BC27C.jpg[/IMG]
Old Nov 23, 2007 | 11:06 AM
  #26
steve05ram360
Old Nov 23, 2007 | 02:55 PM
  #27
KillerCummins's Avatar
KillerCummins
I think I got 30k out of my toyo at's. 33x12.50 They do look cool. I have 22k on my Mud Grapplers and they are starting to show some pretty serious wear. Think I'll be getting a new pair of shoes pretty soon.
Old Nov 23, 2007 | 10:15 PM
  #28
Aero Ram's Avatar
Aero Ram
Truck looks good steve I can't figure it out, yours sits good but so would a 4.5 with 35" and some fender flares...any thoughts
Old Nov 24, 2007 | 10:29 AM
  #29
steve05ram360
the red truck in the pics has 35's on it, Kore leveling kit... Chase series IIRC so you can do the research to see how much lift he has. If your going to take your truck off road, consider the lift or suspension kit your putting together. I've seen lifts where the axle is not centered right and the installing shops try to fix wandering problems thru alignment, they end up with more problems down the road.
Since I've recentered my axle with a thurenfab bar and added the fox steering stabilizer, my truck tracks really straight, tire wear has gone down significantly (my alignment with the tracbar install). If you dont expect to go off road and need good flex along the way, then 4.5 may be right for you, just take a good look at the kit before you commit to it.
also, keep in mind that my rear is only up about 1/2" if that... when I installed the lorenz leaf packs I had the option of removing spacers that were in the origninal pack, there were 3 of them, I took out 1 and got approx 3/8~1/2" of lift. the front went from a 2" spacer to 2.5" of lift.
Old Nov 25, 2007 | 11:51 AM
  #30
energinerbuzzy's Avatar
energinerbuzzy
ORIGINAL: Aero Ram
Hey Aero Ram, I just thought of something. I won't be able to get an accurate calculation of my mpg's because my speedo is off by 5 1/2 mph right now.
Unless someone has a formula to figure it out, I'm screwed till I can get the speedo recalibrated.
