single vs dual exhaust
Old Nov 21, 2007 | 11:33 AM
alnicholson1's Avatar
alnicholson1
Default single vs dual exhaust
I was just curious if there was any power gain difference between the single and the split exhaust or is it mainly just a looks preference??
Old Nov 21, 2007 | 11:40 AM
GFB's Avatar
GFB
Default RE: single vs dual exhaust
No difference. Duals on an inline engine is dumb anyway. Well, except for stacks.[sm=badbadbad.gif]
Old Nov 21, 2007 | 12:20 PM
SinCity R/T's Avatar
SinCity R/T
Generally speaking, your exhaust is only as good as its most restrictive component as far as performance is concerned. Installing dual mufflers/tailpipes won't matter if you have a single 3" pipe sitting upstream. As mentioned above, with an inline engine you only have one exhaust stream, going to duals downstreamwill only help in the looks/sound department.
Old Nov 21, 2007 | 12:44 PM
JimmyDiablo's Avatar
JimmyDiablo
ORIGINAL: SinCity R/T
well put
Old Nov 21, 2007 | 02:44 PM
Drew's Avatar
Drew
also going too big will effect performance seeing as it is more surface area the exhaust gasses have to travel, thus looseing velocity. so your low end suffers.
Old Nov 21, 2007 | 02:52 PM
UpBranchLiner's Avatar
UpBranchLiner
I second
ORIGINAL: GFB
Old Nov 21, 2007 | 04:49 PM
memphisii's Avatar
memphisii
but man black smoke out of both sides of you truck would look sweet not to mention if some one is pissing you off and there on the drivers side of you
Old Nov 21, 2007 | 08:40 PM
Aero Ram's Avatar
Aero Ram
good point memphisii
Old Nov 21, 2007 | 08:53 PM
kingdog's Avatar
kingdog
I kinda like the way mine looks , sounds and smoke X2 is way cool.
Ralph
[IMG]local://upfiles/15626/689ECFFA83924736BDAAF4A415FE857F.jpg[/IMG]
Old Nov 22, 2007 | 12:23 PM
alnicholson1
thanks for the info. I was gunna get stacks but due to mucho soot on the front of my racecar trailer i decided against it. And I'm getting full turbo back exhaust I'm not stayin with the stock piping into the muffler. And I know with the inline it only comes out one side of the motor so its not true duals its just split at the muffler. I was just curious if there was a performance edge one way or the other or if its mainly looks oriented so thanks for the info again
