Engine Oil
Old Nov 23, 2007 | 05:22 PM
behindbars's Avatar
behindbars
Default RE: Engine Oil
ORIGINAL: cmnspwr
Valvoline Premium Blue.
+1
Old Nov 23, 2007 | 08:19 PM
w4phj's Avatar
w4phj
Can't go wrong with Rotella T and a Statopore oil filter.
Old Nov 23, 2007 | 08:34 PM
finny's Avatar
finny
because of some cold weather excurtions to the north i use mobil 1 synthetic
Old Nov 23, 2007 | 09:09 PM
MAB_CTD_4X4's Avatar
MAB_CTD_4X4
ORIGINAL: ZmanTRX4
The stuff they stick in their from the factory is no good. Just my two cents
Correct me if I'm wrong but isn't Mopar oil made by Mobil.
Old Nov 23, 2007 | 09:14 PM
YJBrian91's Avatar
YJBrian91
I've been using mobil delvac. I hadn't really heard of anyone else running it. Is that a bad thing?
Old Nov 23, 2007 | 09:35 PM
MAB_CTD_4X4
My brother has a Cheby and he's tried Rotella and Delvac and according to his on board diagnostics the Delvac stays good long than the Rotella.
Old Nov 24, 2007 | 09:06 AM
Joel_MD's Avatar
Joel_MD
The "on board diagnostics" have nothing to do with measuring oil quality. It's not like there is a small laboratory inthe oil pan with a robot that does spectrochemical analysis and chemical titration! Any car in which the computer calculates oil life does it with algorithms that gather info including miles driven, perhaps the amount of time spent idling, and the duration of each trip. The algorithm probably starts with a figure, say 7,000 miles, and then decrements it every time there is a short trip or any extended idling. It certainly couldn't tell the difference between Rotella and Delvac. Hell, you could fill your crankcase with corn syrup instead of oil and the "on board diagnostics" would continue to calculate your oil life while your engine destroyed itself.
Old Nov 24, 2007 | 10:31 AM
ride0169's Avatar
ride0169
Junior Member
I just changed my oil thought I'd try something different I put 2 an 1/2 qts. of syn and the rest dino along w/12 oz. of torco EAL (engine assembly lube)
Old Nov 24, 2007 | 07:45 PM
YJBrian91's Avatar
YJBrian91
Does anyone think that the Delvac is a bad choice?
Old Nov 24, 2007 | 07:57 PM
07 Ram TRX4's Avatar
07 Ram TRX4
I know at work.... we use the Rotellla ... and usally... we run atleast 10,000 miles between changes... some of us are hard on the trucks... sum are'nt... But for the most part.... the trucks run fine.... just regular wear and tear....
