Truck not starting
Old Nov 26, 2007 | 01:51 PM
esparr1's Avatar
esparr1
Default Truck not starting
Hey guys, for the past few weeks my truck has been unable to start. The main problem seems to be that the engine is not getting fuel. I've noticed that the fuel filter is also half full when this occurs, I always thought that it was supposed to be full. Another issue is that the fuel tank seems to be consistently building up pressure, now the dodge dealer explained t me that this should not happen. Any ideas??? I'm thinking about dropping the tank, replacing the fuel lines, and replacing the sending unit as well. Tell me what you all think.
Old Nov 26, 2007 | 04:13 PM
Drew's Avatar
Drew
Default RE: Truck not starting
so uuummm . . .what year truck we talking about here???
Old Nov 26, 2007 | 08:16 PM
esparr1's Avatar
esparr1
oh wow, I'm sorry, that completely slipped my mind when i was posting this. Anyway I have a 1995 dodge ram 3500 diesel
Old Nov 26, 2007 | 09:39 PM
Kev_n_AZ's Avatar
Kev_n_AZ
fuel pump
Old Nov 26, 2007 | 10:49 PM
Drew's Avatar
Drew
if it is a 95 then you have a mechanical fuel pump mounted on the drivers side of the engine near the back. . .I highly doubt it, but chances are the diaphram has broken, or the ULSD has eaten away at the seals in the fuel lines causing it to suck air.
Old Nov 26, 2007 | 11:01 PM
burban2002's Avatar
burban2002
Kind of a long shot but what happens if you try to start it with the fuel cap off? Isnt the cap supposed to vent and release pressure or let air in so the lift pump doesnt have to work so hard?
Old Nov 27, 2007 | 05:48 PM
esparr1's Avatar
esparr1
Well, i've already replaced the fuel pump and that didnt solve the problem. But you do bring up a good point about the ULSD, because when i first started running this truck I had about a full tank of red dye in it, then when i started to use the highway use diesel i started to get the rough/no starting problem. I'm definitely gonna check into the fuel lines though. I'm at the point where I will probably replace all the fuel lines and fuel line components running from the tank to the fuel pump and take it from there. Also i have tried starting the truck with the fuel cap off, it didhelp a little, but it didnt completely solve the problem. Isn't there a vent hose that runs from the tank thatshould preventpressure from building up?
Old Nov 27, 2007 | 07:33 PM
Drew's Avatar
Drew
yes there is and it often gets clogged.
Old Nov 28, 2007 | 12:11 AM
esparr1's Avatar
esparr1
Ok, thanks a bunch, i'm definitely gonna make sure i check that out
