View Poll Results: A poll
HRVP44
100.00%
SOVP44
0
0%
SHOVP44
0
0%
stock VP44
0
0%
another brand???
0
0%
Voters: 1. You may not vote on this poll
HRVP44 or SOVP44 or else?
Old Dec 1, 2007 | 10:11 PM
woligator's Avatar
woligator
Default HRVP44 or SOVP44 or else?
Who got a HRVP44,SOVP44 or other brand?
what are the pro and con of each of them?
i NEED to get one
Old Dec 1, 2007 | 10:37 PM
GFB's Avatar
GFB
Default RE: HRVP44 or SOVP44 or else?
SO then use the extra $$ to buy some Mach 4's or other decent injectors and sell the jammers. It will drive a lot better with a SO pump and good injectors than the HRVP and any other injector.
Old Dec 2, 2007 | 09:10 AM
woligator's Avatar
woligator
what is the difference between HR,SO,SHO pump?
why gfb say it will drive alot better whit s SO?
some peps are saying than a SO pump will produce more power than a HR whit a box?
and i have hard time finding information about SO and SHO pump
Also what make injector decent? i mean mach one are good one and jammers are crap?
sure jammer are tips only and cost about 250$ and full bodied injector are over 700$
but its because ur paying for the body or because tips only are cheap stuff?
Im only trying to make wise move to upgrade my truck so i wont end buying things 2 times
Old Dec 2, 2007 | 04:36 PM
woligator's Avatar
woligator
i got a quote from a diesel bomber sponsor and hes telling me:
that the HRVP44 produce less hp than a SOvp44 at 950$
i dunno for sure but does SO stand for standart output?
SHO super high output?
Old Dec 2, 2007 | 07:55 PM
woligator's Avatar
woligator
common guys i need some info plz :P
Old Dec 2, 2007 | 08:42 PM
GFB's Avatar
GFB
HO= High Output (used on 245hp stock 6 speeds and designed only for the HO engines). SO= Standard Output (came on everything else and responds to fueling boxes better than the HO pump). HR=Hot Rod(aftermarket only and basically delivers more fuel than the SO or HO). The HRVP44 is known for a horrible lumpy idle and most say it is not worth the extra money. The difference in price between the SO and HRVP44 would be more wisely spend on other mods, unless you are modded like crazy and STILL need more fuel. The jammers are an ok design but the F1 injectors will give you more power with less heat (lower EGTs) and less smoke (yeah it gets annoying at a certain point). I haven't heard about about the SHO pump. I assume they are talking about the HRVP44. I haven't heard anybody that bought the HRVP44 say they would buy it again if they had to replace it.
Also, I just saw your truck was a 6 speed so it probably already has the HO pump. You can use the SO pump but I have heard some complaints about low end power loss when putting a SO pump on a HO engine, but those people also still had the stock HO injectors which have a higher pop-off pressure than aftermarket or SO injectors (the HO pump runs at a higher pressure than the SO pump). If you have the jammer nozzles only and aren't planning on upgrading injectors then I would suggest you get a replacement HO pump so you don't run into any problems or be disappointed from a low end power loss.
Old Dec 2, 2007 | 08:50 PM
woligator's Avatar
woligator
Old Dec 2, 2007 | 08:53 PM
woligator's Avatar
woligator
im looking to get around 600 HP so im wandering about upgrading the VP to get more fuel
if the SO is not better than what i got,no reasons to do so right?
im going to get twins as soon as possible so bigger injectors will be needed but i want to make sure
ill got the fuel to feed them well...
so will swaping a full injector set will do much over a tips swap? i mean tips are around 250$ and full injector range over 700$ and more
Old Dec 2, 2007 | 09:45 PM
GFB's Avatar
GFB
The HO pump cannot deliver enough fuel to support 600rwhp. 500 is pushing it. You will have to go with the SO or HRVP. You will also need some big injectors. Edge really does not make anything big enough to support 600. 600hp has been done many times on a SO pump, but never (unless somebody can show me an example) on a HO pump. Twins will be necessary(unless you get a monster single but then it'll be a bear to drive). Who are you getting them from? I suggest you give BD Power a call. I'm sure they'll be willing to give advice to a fellow Canuck. They happen to have a pretty sweet twins setup too.
Old Dec 2, 2007 | 10:30 PM
Drew's Avatar
Drew
600hp can be done on a VP truck. . .anything over that and you will either need to use some drugs or P-pump it.then you would have all the fuel you want for well over 1000hp.
you have a PM anyway
