Truck just died
Old Dec 3, 2007 | 02:54 PM
Do_What's Avatar
Do_What
Default Truck just died
so the other day i was driving home for lunch and it was like someone just turned the key off on me. the canister seems to have fuel in it and i can't see any reason why it won't start back up. this is my only form of transportation so any help would be greatly appreciated. by the way i have a 99 2wd CTD.
thanks
jake
Old Dec 3, 2007 | 03:20 PM
jakebrake's Avatar
jakebrake
Default RE: Truck just died
Codes?
Old Dec 3, 2007 | 03:31 PM
burban2002's Avatar
burban2002
I would check the lift pump. Mine did the exact same thing a while ago. Check for codes using the key and dont keep trying to start it until you know the fuel pressure is ok.
Old Dec 3, 2007 | 04:30 PM
jakebrake's Avatar
jakebrake
His is a 99 he won't be able to do the key trick (that started in 2000 or 2001). He'll need to get a code reader.
Old Dec 3, 2007 | 04:41 PM
Do_What's Avatar
Do_What
the only code i found was a low circuit imput code that it has thrown in the past. thanks for the imput thus far i just went and bought the lift pump hopefully that solves the problem.
Old Dec 3, 2007 | 05:39 PM
04QC4X4's Avatar
04QC4X4
I got a high ciruit input code when my lift pump went out, but my truck did the same thing, just died while I was going 45 mph. Good luck on fixing the problem.
Old Dec 3, 2007 | 06:26 PM
R0oster31's Avatar
R0oster31
Do you have a chip?
Old Dec 5, 2007 | 09:01 AM
Do_What's Avatar
Do_What
ORIGINAL: R0oster31
Do you have a chip?
No i don't have a chip. I put the lift pump on and that solved the problem. Thank you guys so much for all your help
Old Dec 5, 2007 | 09:09 AM
NCcummins's Avatar
NCcummins
glad to hear you got it fixed....
Old Dec 5, 2007 | 07:33 PM
04QC4X4's Avatar
04QC4X4
Glad we could help.[8D]
