door sealing 02 ext cab
Old Dec 3, 2007 | 09:48 PM
diesel04's Avatar
diesel04
Default door sealing 02 ext cab
hello guys, theres got to be a way to fix this. i will be driving along about 70kph and above and if its a bit windy all i can hear is the wind shaking the doors aorund, almsot sunds likethe winds sneaking inand i can stick my finger up near the seal and feel the door shaking back and forth. i know with my old car(honda prelude) i jsut adjust those clips that the door mechanism clamps to( rectangle shaped bar the door locks onto). i tried moving the clamp in and out but the door didnt lineup anymore, what else is there? thanks boys and girls!
Old Dec 3, 2007 | 09:54 PM
04QC4X4's Avatar
04QC4X4
Default RE: door sealing 02 ext cab
Mine is the same way. It is extremely loud when the wind is blowing across the truck. I'm not sure if you can adjust anything, but I'm sure someone will know.
Old Dec 4, 2007 | 08:25 PM
jakebrake's Avatar
jakebrake
After looking at mine for a bit I dont see and adjustment for it. I would run some of that pvc foam tape along the door where it contacts the weather stripping and see if that helps. Napa should carry some. You want pvc foam because it recovers from compression better then the other types of foam tape out there.
Old Dec 4, 2007 | 08:56 PM
Aero Ram's Avatar
Aero Ram
My doors seals blew out 4 times on my 04 1500...they can make a bad *** truck just the way they designed the doors catches alot air up along the a-pillar
