heater cord
Old Dec 7, 2007 | 07:13 PM
2008cummings's Avatar
2008cummings
Default heater cord
so got the cord from genos but no directions... anyone have a pic or can explain where to run the cord? any help will be great
Old Dec 7, 2007 | 07:30 PM
NickBeek's Avatar
NickBeek
Default RE: heater cord
It plugs in on the side of the block near the oil filter. Then I just figured out where to run it. I ran mine on the inside of the frame rail and used wire ties to keep it where I put it.
Old Dec 7, 2007 | 07:38 PM
2008cummings
I got the kind with thr factory plugs I hope is easy enough and how you access the heater element from below or wheel well or top?
Old Dec 7, 2007 | 07:44 PM
BrianSudokhoi02's Avatar
BrianSudokhoi02
I did mine from the bottom
Old Dec 8, 2007 | 09:57 AM
Aero Ram's Avatar
Aero Ram
your pry done already but I knew I had this pic forsomething
[IMG]local://upfiles/50970/E8BECFD3FFE544D097A76ED4C050E27C.gif[/IMG]
[IMG]local://upfiles/50970/DDEB00DB90BD4C298C898C5F9AC74D74.gif[/IMG]
Old Dec 8, 2007 | 09:58 AM
Aero Ram's Avatar
Aero Ram
Not sure how I loaded it twice....just woke up gimme a break....
Old Dec 10, 2007 | 11:54 AM
2008cummings
ok figured it out pretty easy and the cord from genos made it really easy with the factory plugs to mount into the rails. took all of 5 minutes... Will use but not really cold enough yet. only like 30 degrees at night. Doesn't even High idle now. Only did that once or twice when was really cold like 25 degrees the few mornings.
