tps info??
Old Dec 10, 2007 | 06:52 PM
Parts/Service's Avatar
Parts/Service
Default RE: tps info??
Kev, I have the 93 Cummins electrical manual . I am taking it home with me and will try and help you. Will be home about 8:30 est.
Old Dec 10, 2007 | 06:58 PM
NCcummins's Avatar
NCcummins
ORIGINAL: Parts/Service
thats a good man for you right there!
btw...did you try to call me today? i called the missed call number back and came to your voice mail. PM if you need something!
Kev_n_AZ's Avatar
Kev_n_AZ
thank you very much!!!
[sm=happybounce.gif]
Old Dec 10, 2007 | 07:40 PM
Kev_n_AZ's Avatar
Kev_n_AZ
it has been suggested that my trans linkage at the fi pump .
Old Dec 10, 2007 | 08:37 PM
Kev_n_AZ's Avatar
Kev_n_AZ
ok so how do I adjust the trans linkage at the fi pump ??
I tried, but no difference.
Old Dec 10, 2007 | 10:15 PM
Parts/Service
Finally made it home...Had to finish working on a '73 Bronco...
Old Dec 10, 2007 | 10:38 PM
steve05ram360's Avatar
steve05ram360
ORIGINAL: Kev_n_AZ
Steve
does the tps control the signal to the trans that tells it to "kick down" when you mash it????
Not sure how the tranny downshifting is controlled but on the obdII rams/daks, a dirty tps will cause surging which ends up being the TC locking & unlocking. with your truck being that old, it couldnt hurt to clean it anyways.... I'm assuming it's similar to the one in the writeup...???
Old Dec 10, 2007 | 10:46 PM
Parts/Service
Kev. The Cunnins manual talks about using the DRB III diag tool to diag the TPS. Tomorrow I will call a 12 valve Guru that I know. If you want I can give you his #. He has his own shop and is the MAN on 12 valves....Let me know or call me @ 1-800-663-2522 and I will get you in touch with him.
Old Dec 10, 2007 | 10:47 PM
Kev_n_AZ's Avatar
Kev_n_AZ
COOL MAN!!!
btw I found where to adjust the trans kick cable at the fi pump. I will post pics tomorrow.
