Transmission Hum
Old Dec 11, 2007 | 07:50 AM
zixxer10r's Avatar
zixxer10r
Default Transmission Hum
My tranny on my03 2500 with 60k on it is starting to generate a humming noise between 60 and 70 mph. I just started to hear it and it is getting to be annoying. The fluids are good and not burnt in color. Is this considered the norm? I believe it is the 47re. Shouls I drop the pan and put some good quality fluid and will that get rid of the noise. I don't want to cover up a problem that I might be able to fix now and save some big dollars later.
Old Dec 11, 2007 | 12:45 PM
Mayfair's Avatar
Mayfair
Default RE: Transmission Hum
Are you sure it's the trans and not your rear?
You might just need to change the fliud in your diffs.
Old Dec 11, 2007 | 01:23 PM
behindbars's Avatar
behindbars
Maybe its a bad u-joint.
Old Dec 11, 2007 | 09:11 PM
beachmstr's Avatar
beachmstr
my first thought was a u joint as well. Is there any vibration in the pedal?
Old Dec 11, 2007 | 09:15 PM
04QC4X4's Avatar
04QC4X4
I had a whine and a vibration between 70 and 75. I change all 3 u-joints on the front axle and its like new. That would be my first guess as to what is causing your noise.
