High Idle? Need Help!!
Old Dec 13, 2007 | 10:57 PM
Drew's Avatar
Drew
Default RE: High Idle? Need Help!!
you have to disconnect the plug, remove the blank that is there, insert the wire you can get directly from cummins, then you will need to have some extra wire handy to extend it to the frame to ground it out.
Old Dec 13, 2007 | 11:19 PM
memphisii's Avatar
memphisii
is there a certain part number ether front cummins or from dodge for the wire? or does cummins only use one style of connector wire?
Old Dec 13, 2007 | 11:32 PM
Drew's Avatar
Drew
you can only get the wire from cummins. . . The Pig tail part number is 3824810, bring $12 with you and your out the door.
Old Dec 13, 2007 | 11:34 PM
memphisii's Avatar
memphisii
awesome thanks, your wife must love all the time you spend logged on.
Old Dec 15, 2007 | 02:57 PM
amock's Avatar
amock
Nick, Bully Dog screwed with my computer and ended up putting the truck in fuel limp mode. I had no low end power at all, it was like driving a gasser with a plugged cat. So, after it blew my boost pressure sensor, and a reflash, not to mention tear the wastegate down to get unplugged, ended up being about $600 dollars for all this. Pain in the @#%$in ***. I also know a lot of guys here in Missouri that have had tons problems. One guy had a powerjoke with triple dog downloader and it ruined the entire computer. So, no bully dog for me.
Old Dec 16, 2007 | 12:24 AM
Drew's Avatar
Drew
ORIGINAL: memphisii
I do most of my time here while I'm at work. . .where I get payed to do this
Old Dec 16, 2007 | 07:12 PM
justviper1's Avatar
justviper1
does my 01 have this high idle feature? or is it just the 3rd gens.
Old Dec 31, 2007 | 09:30 PM
Aero Ram's Avatar
Aero Ram
I know this post is kinda old but I just got home... anyways When I used my smarty to program it automatically enabled it. I turned it back to stock and it still worked to so I guess if you know someone with a smarty you could just program up to one of the settings then go back to stock and it should stay...
Old Jan 1, 2008 | 06:37 AM
Super Dave's Avatar
Super Dave
Aero, was there an option in the Smarty to enable it, or was it just part of the program and itenabled it automatically?
Old Jan 1, 2008 | 05:39 PM
Aero Ram's Avatar
Aero Ram
I guess its part of the program... I didn't have it before then programed it and tried it and it worked [&:]. Turned it back to stock and it still works so it must do it automatically, Buzzy had some kinda post on High Idle and trying to get it to work, he has a Smarty Sr. though maybe there different [&:]
Anyone with a smarty jr or sr. can add in....
