towing
Old Dec 18, 2007 | 02:45 PM
cookie88's Avatar
cookie88
Default RE: towing
BTW love your old 12v, I have an 89 but non diesel[:'(], working on that part....
Old Dec 18, 2007 | 02:55 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Default RE: towing
ORIGINAL: cookie88
you will need a 5500# rated front axle to have a CTD power supply!
basically rape another wrecked ctd for its suspension. the earlier dodge trucks (with ctd) twisted front ends due to undrer rated front axles.
Old Dec 18, 2007 | 03:00 PM
cookie88's Avatar
cookie88
Default RE: towing
haha thanks but as far as my old one, it's been half wayrestored and is in a barn right now, waiting to be stripped for12v drag setup in the future,other finacial prorities at the moment, but getting ready to nab an 03 for Daily driver, I love the clean first gens, you dont see them alot
Old Dec 18, 2007 | 03:13 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Default RE: towing
no the 1st gens are history for the most part. sad sad day it is...
Old Dec 18, 2007 | 03:41 PM
cookie88's Avatar
cookie88
Default RE: towing
agreed
Old Dec 18, 2007 | 03:58 PM
agargano98's Avatar
agargano98
Default RE: towing
trailer tires were good, and i have the proper drop on the ball so it does ride level. thanks for the suggestions
Old Dec 18, 2007 | 04:13 PM
cookie88's Avatar
cookie88
Default RE: towing
your welcome......happy towing [8D]
Old Dec 18, 2007 | 05:10 PM
Mayfair's Avatar
Mayfair
Default RE: towing
Got any nice boat pics ??
Old Dec 18, 2007 | 06:48 PM
behindbars's Avatar
behindbars
Default RE: towing
Don't forget your personal flotation devices.
[IMG]local://upfiles/75003/532F4954A10A45C6946D1768B0C364E1.jpg[/IMG]
Old Dec 18, 2007 | 07:53 PM
KenZ's Avatar
KenZ
Default RE: towing
A little more hitch weight would help, but with a boat its kinda hard to do that. Air up the truck tires to the max amout listed on the tires. This will eliminate flex in the tires. A friction bar will also help. Do you have a sway bar on the rear axle? If not this will help also. Your snowmobile trailer will more than likely pull a little better because you can add a little more weight to the tongue. It is better to have the tongue alittle low than alittle high with level being what you want. You can go to a local RV dealer and he can show you the bars, and describe to you how they work as most travel trailers need this stuff to go straight down the road. I never run my tires at any amout less than max rating on the side of the tire. But then again, my fifth wheel has a tongue weight around 3000-3200lbs.
