towing
Old Dec 18, 2007 | 01:49 PM
agargano98's Avatar
agargano98
Default towing
i had to bring my boat to the dealer last week. i have a class 5 14000lb tow beast hitch. my boat motors and trailer weigh aproximately 10000lbs and i have about 900lbs on the tongue. when i was on the highway doing about 70mph, the motor didn't even feel the boat. the 6 speed auto with jake brake worked awesome. the only thing that made me uncomftorable was the rear end had alot of sway and felt mushy. i have single wheels running at 60psi per the label on the door. if i air them up to 80 will it make it better, or is there anything else i can do? i only went 3 exits on the highway, but i snowmobile 400 miles away and will be towing a 38' enclosed trailer that is 12000 lbs. just looking for some suggestions.
Old Dec 18, 2007 | 01:54 PM
cookie88's Avatar
cookie88
Default RE: towing
you can try a little more air, and maybe some weight on the tougue, unless your at your limit, thats a pretty heavy load, your gana have some sway no matter what.And just a note that theres no jake brake on these trucks, just an ex-brake, those are for the big boys..haha
Old Dec 18, 2007 | 02:06 PM
agargano98's Avatar
agargano98
Default RE: towing
thanks i'll give it a try. i guess my next truck will be a freightliner.
Kev_n_AZ's Avatar
Kev_n_AZ
Default RE: towing
equalizer chains or bar. keeps the sway to a minimum.
Old Dec 18, 2007 | 02:23 PM
cookie88's Avatar
cookie88
Default RE: towing
haha..no prob and if it's still bad try what Kev said, although thats a little pricer
Old Dec 18, 2007 | 02:33 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Default RE: towing
ORIGINAL: cookie88
jake is a brand of exhaust brake
(jacobs brake)
Old Dec 18, 2007 | 02:36 PM
behindbars's Avatar
behindbars
Default RE: towing
Did you check the air in the trailer tires? If they're a little low they'll sway. Also if the trailer tongue height is too low it will sway. You want it level or the tongue to be a little higher. Boats are tough cause all the weight is on the back end. When you load your snowmobile trailer just try to keep as much weight forward as you can.
Old Dec 18, 2007 | 02:42 PM
cookie88's Avatar
cookie88
Default RE: towing
(jacobs brake)
your right, but as most normal people think of jake brake on semi's. Jacobs brakes are used throught the vavle train, whole different setup,on the light duties these exhaust brakes are just basiclly flapper vavles in the exhuast piping
Old Dec 18, 2007 | 02:43 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Default RE: towing
ORIGINAL: cookie88
(jacobs brake)
point and set to cookie88
Old Dec 18, 2007 | 02:44 PM
cookie88's Avatar
cookie88
Default RE: towing
haha thanks
