weird sounds
Old Dec 18, 2007 | 09:58 PM
mossy765's Avatar
mossy765
Default weird sounds
hey guys i got a 94 cummins and when im sittin in the cab with the truck idling its sounds like to me u can hear like coolant runnin to the heater box and i have never heard this noise b4 and i was wonderin what i should do bout it.....im gittin ready to change my thermo tomm cause its not gittin up to temp. but i didnt kno if that had something to do with it or not but i thought it was jus weird any answers would b appreciated thanks
Old Dec 18, 2007 | 10:12 PM
Parts/Service's Avatar
Parts/Service
Default RE: weird sounds
If you can smeel or "taste" something sweet while sitting in the cab, your heater core may be leaking.....
Old Dec 18, 2007 | 10:24 PM
mossy765's Avatar
mossy765
no i cant smell anything i can jus hear it
Old Dec 18, 2007 | 11:36 PM
Kev_n_AZ's Avatar
Kev_n_AZ
is the blower fan on for the heater-a/c system???
you may have a loose fan or debris in the fan when on low speeds makin funny noises.
I would back flush the cooling system.
1-use the radiator flush solution to clear out the junk
2-cut a T in and back flush with a hose.
3-fill back up with 50/50 mix
wont cost too much scratch and will be a PM at the same time
Old Dec 19, 2007 | 12:47 AM
6inarow's Avatar
6inarow
My 97 makes that noise every morning when I start it, has since new, But mine only does it in the morning when started, only lasts a few seconds though! Sounds like water running through a plastic pipe.
