need thoughts on this
Old Dec 21, 2007 | 02:49 PM
JimmyDiablo's Avatar
JimmyDiablo
Default RE: need thoughts on this
Well, I went out and was trying to start Diablo and when I bumped it, like when changing a filter I did not hear any pump running so I am thinking the pump is gone. Time to upgrade. just need to pay a few bills first and I will be set. looks like Diablo will sit a month or two Thanks to Christmas.
Old Dec 21, 2007 | 03:05 PM
UpBranchLiner's Avatar
UpBranchLiner
Are you running any power service Jimmy?
Old Dec 21, 2007 | 03:24 PM
JimmyDiablo
I was up until this tank. I had filled up, brought it home. parked it and was going to get some at the truck stop on the way to work.
Old Dec 21, 2007 | 03:39 PM
Kev_n_AZ's Avatar
Kev_n_AZ
ORIGINAL: bksram3500
It shouldn't be cold enough in Phoenix to keep it from starting.
believe it or not, when the weather says "30+' here, its actually about 15 in front of a house!!
the official weather station is at Phoenix Sky Harbor Airport and may not be in the WIDE open...
I have been using my hand held thermal scanner this week to check the morning temps at home. my stat on the house says like 40, but when you scan the front yard and open street, its 15 - 25F at 6AM!! (yes, I made sure it was on F not C ).
the variance from structure to open ground temp readings is amazing!!
Old Dec 21, 2007 | 03:40 PM
UpBranchLiner
Hell Id try a new filter and power service.
Old Dec 21, 2007 | 03:58 PM
JimmyDiablo
ORIGINAL: UpBranchLiner
I will give it a try. it has a new filter in there (150 miles) but I can change it again. and I will add a gallon of power service.
Old Dec 21, 2007 | 05:01 PM
solarwarp's Avatar
solarwarp
Do you have a heated garage you canpush Diablo into and let it warm up overnight night?
Just asking, does PS mix with WVO?
Also, does the LP have a fuse or circuit that would pop, before the pump goes?
Old Dec 21, 2007 | 09:04 PM
JimmyDiablo
Diablo does not fit in my garage. He is too tall
Have no Idea but I used it the past three tanks just in case
That is a great question and I will have to search for a answer. I should check all my fuses now that I think about it.
