need help with a code
Old Dec 26, 2007 | 12:52 PM
fireflycomeau's Avatar
fireflycomeau
Default need help with a code
does anybody know what the code p0628 means.
thanks
Old Dec 26, 2007 | 01:00 PM
triton's Avatar
triton
Default RE: need help with a code
that dreaded lift pump code ! Don't know what year you have but, the LP's are known to go bad and need replacing. An aftermarket pump is what's recommended.
P0628 = Fuel Pump Relay Control Circuit Low Voltage
Do you have any problems or just the code ? It may not be the pump, it could be something electrical too
Old Dec 26, 2007 | 01:18 PM
aka_chewy's Avatar
aka_chewy
I just received that code a few weeks ago and I had to replace the lift pump. Due to circumstance and timing, I had to go with a factory replacement from Geno's, but am going to upgrade to a Walbro setup from Glacier Diesel as soon as I can.
What year truck do you have?
Old Dec 26, 2007 | 04:22 PM
CowboyBob's Avatar
CowboyBob
Idon't think that PO628 is one of the death codes for the VP44 is it? Not knowing what year truck he has makes it difficult to narrow down.
