Tranny Info??
Old Dec 31, 2007 | 10:43 AM
sunchaser5.9's Avatar
sunchaser5.9
Default Tranny Info??
Where can I get some GOOD troubleshooting info on the 47RE?? There seems to be no good diagnostic info available. I have been having trouble with mine for some time. I have had it rebuilt recently, now seems to not have TC lockup...or no OD not sure which. It seems to be shifting into 4th with no lockup on the converter.....no RPM drop like it used to have...........HELP
Old Dec 31, 2007 | 11:11 AM
Kev_n_AZ's Avatar
Kev_n_AZ
Default RE: Tranny Info??
how long ago was it rebuilt?
is it still under warranty?
trans info is slim to none sorry to say.
could be low fluid, misadjusted bands, bad tc...
Old Dec 31, 2007 | 11:44 AM
energinerbuzzy's Avatar
energinerbuzzy
WOW I thought this topic was about something else. I was going to give him Sharx and Jimmy's numbers and share some pictures with him !!
Old Dec 31, 2007 | 12:23 PM
Super Dave's Avatar
Super Dave
Just don't do what I mistakenly did when I was searching for rebuld info for an NP 435 trans for my old F250.
I did a google search and included the word "tranny" [:'(][:'(][:'(][:'(][:'(]
Old Dec 31, 2007 | 12:33 PM
lilfroger's Avatar
lilfroger
Sun please excuse our boys here ^^ (come on guys he is new don't scare him off yet ) Yes someone will have some info for you....forgive the jokes...we do that a lot around here.
Old Dec 31, 2007 | 12:45 PM
Super Dave's Avatar
Super Dave
ORIGINAL: sunchaser5.9
Actually, I think this sounds like what Drew was describing the other day in the second gens wherebad grounds were causing shifting problems.
The solution was to remove and clean the battery cables and bonding wires to the engine and trans. If the trans and electronics aren't properly gounded, then the sensors can't obtain an accurate reading and it won't shift correctly.
Old Dec 31, 2007 | 05:14 PM
sunchaser5.9
Thanks to all, I have heard of and performed all the ground cleanings, The truck is just put back together after the rebuild on the trans, I put in a TCS converter, kevlar bands, heavier clutchs, transgo shift kit. I have all the shifts 1-4 seems like there is no lock up on the converter. The guy that did the rebuild has no idea whats going on with it. There are no codes with the key switch( CEL). There is one code on the digital odometer, I think it was for the turbo though.
I have been under this truck way too much lately. I have changed the shift govenor solenoid prior to rebuild. I switched out the VSS on the tailshaft case. Lil Frogger, thanks for the support...............Randy
