Boost PSI
Old Dec 31, 2007 | 08:35 PM
lee8751's Avatar
lee8751
Default Boost PSI
Just got finished installing the boost, EGT, and fuel pressure gauges today. Took longer than I thought it would but at my age everything takes longer to do. On the test drive I punched it and blue off the boost tube on the gauge end. It popped up to 30PSI before the tube came off. (Maybe I didn't have it on all the way). I have a 30PSI gauge should I have the 60PSI gauge? Running the Smarty JR at stage 1 setting right now. How many PSI boost are you guys running with the Smarty Jr and at what settings.
Old Dec 31, 2007 | 09:04 PM
Drew's Avatar
Drew
Default RE: Boost PSI
I take it you have a HPCR engine. . .I would say 35psi is where she went to. . .which is normal for even a stock truck. I have a 35psi gage and there are MANY times I wish I had a 60. besides, with the stock turbo you dont want to push much more than 40-45 or your EGT's will get out of control.
I had the same issue you have when I installed mine. . .first time I gave her all she had I heard the ppppsssssshhhhhhh of the tube popping off. [:@]
get yourself another zip tie and you'll be good.
Old Dec 31, 2007 | 09:44 PM
lee8751's Avatar
lee8751
Your right I have the 06, 5.9. If I peg the gauge will I trash it? I just got the gauge I could exchange it at Geno's for the 60 PSI. Thanks
Old Dec 31, 2007 | 09:57 PM
04QC4X4's Avatar
04QC4X4
My stock 04.5 will hit 38 psi on a good run, but will easily reach 33-35 psi, so I would go with the 60 psi gauge.
Drew's Avatar
Drew
Ive pegged mine more times than I can count. . .that electronic wastegate can be a little slow on the open sometimes
still works good. . .before I installed it I put it next to the pneumatic pressure standard I have at work. . .it was less than 1psi out. so it was realy close. . .the EGT I had to tweak a bit, but was still good.
Old Jan 2, 2008 | 07:58 PM
bluecummins's Avatar
bluecummins
i have a 2000 cummins stock was only 25 now getting 35 i have a 60 psi gauge go with the 60
