Wich will force regen on 07.5 6.7
Old Jan 2, 2008 | 07:21 PM
Diesel Man's Avatar
Diesel Man
Default Wich will force regen on 07.5 6.7
New guy to the forum!!
Wich programer or module will let you force Re-gen while your truck is in park?? Is this something that is available yet?? [sm=headbang.gif]
Old Jan 2, 2008 | 09:12 PM
Joel_MD's Avatar
Joel_MD
Default RE: Wich will force regen on 07.5 6.7
There is no programmer that I know of that will allow you to trigger the DPF regeneration. I can set an alarm on my Edge Attitude monitor that will sound when the regen begins, but there is no way to force the regen cycle. Anyway, it wouldn't make any sense to do the regen when the truck is in park. From what I can tell with my Attitude monitor, the regen cycle is temporarily interrupted when the engine is at either idle or full throttle. I guess 'full throttle' is not the proper nomenclature for a diesel, but you know what I mean.
Old Jan 2, 2008 | 09:21 PM
Diesel Man's Avatar
Diesel Man
So the Edge also serves as a regen monitoring device aswell. Have you had any problems with your Edge? I had a Quadzilla on my 05 and when driving it felt like slight pulsing in the engine when on cruise control (65mph). Finally my lift pump went out, I think this has scared me from buying another power adder.[sm=gears.gif]
Old Jan 2, 2008 | 09:37 PM
Joel_MD's Avatar
Joel_MD
The only problem I had is the boost pressure reading is faulty. It shows 29 or 30 PSI all the time. I was part of the beta test for the 6.7L Edge Juice w/ Attitude, and when I reported the problem they sent me another Attitude monitor free of charge. I have been too lazy to install the new one, so I don't know if that will fix it or not.
I normally drive it in Mode 0 (stock), because that seems to give better fuel economy than Mode 1 (mileage). The higher numbers give abig boost in HP and responsiveness. And soot/smoke!
Old Jan 2, 2008 | 09:42 PM
Diesel Man's Avatar
Diesel Man
Thanks for the info, all the best.
Old Jan 9, 2008 | 12:45 PM
Stang_luvr's Avatar
Stang_luvr
Joel,
you actually able to get soot/smoke from the 6.7 with the edge juice? Just curious...didn't think it would d/t the dpf and cat...really makes me want to get one now....hehehehe
Darryn
Old Jan 9, 2008 | 01:49 PM
Joel_MD's Avatar
Joel_MD
Hell yes, if I set the Juice to 2 or higher it smokes like crazy. It must be completely filling the DPF and then spilling over or whatever, and it regens a lot. I'm hesitant to use theJuice on any setting other than stock because of this. Someday I intend to delete the DPF; then I'll crank up the Juice and there will be so much smoke it will look like someone opened the door to an Indian casino!
