Code p0628
Old Jan 3, 2008 | 10:05 AM
rcm1989's Avatar
rcm1989
Default Code p0628
2003 2500 5.9L ctd. Engine quit running on the side of the road last week. The code read (p0628), low voltage fuel circuit. I cracked open the fuel filter and replaced the fuel filter. Still didn't start. After cranking over a few times I noticed no fuel was getting into the fuel filter bowl. I tested several thigs and found that the lift pump that should show 5 amps was unresponsive when I tested it with a meter. The book says it's comming from the ecm. Has anybody had this problem?? I am not getting the whirl wind sound from the pump so, I know it's not working. All relays have been checked and feses look fine. Anysuggestions would be greatly helpful.
Old Jan 3, 2008 | 10:27 AM
Watermelon's Avatar
Watermelon
Default RE: Code p0628
The lift pump is gone. My 04 did the same thing last year. It is covered by the 100k warranty. I would not keep trying to crank it. Good luck
Old Mar 28, 2008 | 08:37 AM
kdtlr's Avatar
kdtlr
RCM1989,
Waas this te fix for your problem? My truck is throwing te same code as I write. Please let me know how it worked out for you. thanks
kevin
Old Mar 28, 2008 | 08:54 AM
12valveman's Avatar
12valveman
is a failed fuel lift pump
Old Mar 28, 2008 | 09:24 AM
kdtlr's Avatar
kdtlr
Thanks, I have a call into Dodge to see if itwould becovered under the 100k mile cummins warranty. Anyone know for sure if it would be covered or should I take care of it myself?
Old Mar 28, 2008 | 10:48 AM
12valveman's Avatar
12valveman
if you do not have a damage disclosure on the pickup that would have voided the warranty and if you are int the 5yr 100k you are covered
