electric fans
Until they have one capable of the cooling capacity that we need, you will want to stay with the clutch, you can add aa electric fan as a secondary, but not primary especially if you run any load at all.
Plus, since the ECM controls the clutch fan, at least in our 06's.... an electric alternative may set a fault...An electricfan would have to pull a ton of current to flow the air the clutch fan does, Idoubt there would be any gain in efficiancy. An auxilary fan in front of thecondensor with it's own stand-alone control logic may beok... are you having performance issues with your current setup?
