Front Suspension Question
Old Jan 11, 2008 | 07:05 PM
04QC4X4's Avatar
04QC4X4
Default Front Suspension Question
I have a clunking coming from the front end and I got underneath today and the only thing that I could find that was loose was the sway bar or stabilizer bar. I'm not sure what its called, but it runs through two bushings and I can rattle it around inside both bushings. Is this normal? I can reproduce the clunking sound just by shaking this bar.
Can these bushings be replaced?
Old Jan 11, 2008 | 08:18 PM
Parts/Service's Avatar
Parts/Service
Default RE: Front Suspension Question
If you mean the sway bar bushings, #14 in the pic, Yes they are replacable and they should be tight. Bushing part # is 52113085AB and retail for $15.20
Old Jan 11, 2008 | 10:11 PM
steve05ram360's Avatar
steve05ram360
I replaced mine with energy suspension ones... $10 bux.
Old Jan 11, 2008 | 10:25 PM
04QC4X4's Avatar
04QC4X4
Yes, that's exactly what I'm talking about. Where can I get them?
Old Jan 11, 2008 | 10:38 PM
04QC4X4's Avatar
04QC4X4
Do I remove the sway bar and slide them on or what?
Old Jan 11, 2008 | 10:49 PM
Parts/Service
I can get them for you or you can go to your local dealer. Lots of aftermarket companies offer them.
REMOVAL [ol][*]Raise and support the vehicle.[*]Hold the stabilizer link shafts with a wrench and remove the link nuts at the stabilizer bar.[*]Remove the retainers and grommets from the stabilizer bar links.[*]Remove the stabilizer bar link nuts from the axle brackets.[*]Remove the links from the axle brackets[*]Remove the stabilizer bar clamps from the frame rails and remove the stabilizer bar. [/ol]
Old Jan 11, 2008 | 10:52 PM
04QC4X4's Avatar
04QC4X4
Thanks Parts/Service. I'm relieved to know where the clunking is coming from. It's been getting worse over time, but should be an easy fix.
Old Jan 11, 2008 | 11:05 PM
Parts/Service
Is a very easy fix. Let me know if you need more info.....DAVID
