tires
Old Jan 13, 2008 | 11:44 AM
rsmackenzie@shaw.ca's Avatar
rsmackenzie@shaw.ca
Default tires
I recently put taller tires on my truck which has really robbed horse power. Some one told me you can change the ratio in the auto tranny thru the computor.Sounds a little far feched to me, have any of you guys dealt with this issue?
Old Jan 13, 2008 | 11:46 AM
tdmopar59's Avatar
tdmopar59
Default RE: tires
What kinda truck year, model, 4x4? wat size tire... wat mods are done to it?
Old Jan 13, 2008 | 11:59 AM
energinerbuzzy's Avatar
energinerbuzzy
Default RE: tires
ORIGINAL: rsmackenzie@shaw.ca
Yes you can and need to have your tire size changed in the ECM. It will correct your speedometer that is now off a bit and will correct the shift points in the tranny.
However, correcting the ECM will not give your HP back. You will need to get a programmer to add a little HP to get fuel milage and HP back. Basicly what you did by putting taller tires on it was , you basicly gave it higher gear ratio's.
I have 35"s on my truck and noticed the same performance drop and loss in fuel milage. I bought the "Smarty" programmer and corrected the tires size and added a little horse power, now it's better than it was before
Go to your dealer and they can program the correct tire size for you.
Old Jan 13, 2008 | 07:19 PM
CowboyBob's Avatar
CowboyBob
Default RE: tires
You can correct the speedo with a Hypertech programmer too. You could probably justify buying the programmer with what the dealer is going to charge you.
