Power Problem, Please Help!!!
Old Jan 13, 2008 | 08:11 PM
trueforlife99's Avatar
trueforlife99
Default Power Problem, Please Help!!!
98 24 valve turbo diesel, manual transmission. In 4th gear, a little in 5th also, my engine revs higher when i hit the pedal, than what my truck will actually go. almost like when your driving and hit a patch of ice, higher rev, truck wont go faster. I changed fuel filter less than a week ago and it seemed fine the next day. then acted up a bit, but not bad as before. installed a hypertech max programmer and then had that same power problem in 3rd, 4th, and 5th gear, so i programmed truck back to stock, and now problem is back to 4th gear only. I also changed my crankshaft position sensor within 6 months ago. any clue? please help... [/align]
Old Jan 13, 2008 | 08:21 PM
Super Dave's Avatar
Super Dave
Default RE: Power Problem, Please Help!!!
It sounds to mw like the clutch is slipping. Sounds like you need to baby it until you can get it changed.
In any gear, the truck should accelerate commensurate with an increase in RPM.
Old Jan 13, 2008 | 08:32 PM
trueforlife99
Also, The problem doesnt happen during shifting gears, it shifts fine, and the pressure of the clutch pedal is fine. It happens while driving in 4th gear, it will do it multiple times if i hit the gas pedal multiple times in the same gear.
Old Jan 13, 2008 | 09:05 PM
04QC4X4's Avatar
04QC4X4
Sounds like the clutch to me also.
Old Jan 13, 2008 | 09:37 PM
jakebrake's Avatar
jakebrake
clutch is slipping. Time to get a new one.
Old Jan 14, 2008 | 01:32 AM
clops79's Avatar
clops79
you burnt up your clutch. you have a hyd actuated clutch so you wont notice any diffirence in pedal. turn programer back on and see if more gears slip again.
Old Jan 14, 2008 | 04:22 AM
Aero Ram's Avatar
Aero Ram
Yup clutch, Look on the bright side now you get to get that High Performance clutch that woli is wanting congrats
Old Jan 14, 2008 | 06:36 AM
trueforlife99
well hell, i guess thats a good way to look at it, when i had programmer in it slipped in 3rd, 4th, and 5th. so new clutch it is!!! thanks everyone!
Old Jan 14, 2008 | 06:39 AM
Aero Ram's Avatar
Aero Ram
Yeah kinda sucks when your not plannin on fixin somethin but ya gotta look on the bright side, and that is that you getta make woli jealous, hope it goes together smoothly but if not...at least you know where to come
