lift kits
Old Jan 21, 2008 | 02:15 AM
coosaguy's Avatar
coosaguy
Default lift kits
i have a 2002 2500 4x4 diesel and i can fit 33's on it now with no lift kit. if i went with a 3 inch suspension kit what are the biggest tires i could fit with out scrubbing?
Old Jan 21, 2008 | 04:20 AM
Aero Ram's Avatar
Aero Ram
Default RE: lift kits
I had an 04 2wd gasser with 34x 11.5 with no rubbin I put on a leveling kit and it sat nicely I will be puttin on a 35x12.5 on the stock rim and everyone is saying she won't rub if ya believe this take the rumor for what its worth but I will be puttin on 35x12.5 w/n a short time and will post on it and rubbin an all I'll level soon after for stance as well....It should work w/stock rims
Old Jan 22, 2008 | 12:19 AM
02cummins's Avatar
02cummins
just get a 5" tuff country lift
Old Jan 22, 2008 | 02:18 AM
Mayfair's Avatar
Mayfair
ORIGINAL: coosaguy
What size tires are you running? I know you said 33's, but what's the rest of it? ( 33/75/16 ... ect ) I'm getting ready to get some tires as well but i don't want to lift the front end.
Old Jan 22, 2008 | 07:38 AM
GOD RAM IT's Avatar
GOD RAM IT
this topic will go on for ever with people saying they have 35s and 33s with and with out lifts. bl bla bla
the truth is. if you rub now than a leveling kit is your cheapest bet. if you're going to jump up in tire size some day than go with a 4 or 5 inch kit.
also. stock rims will usually not have enough backspacing with any amount of lift the width of the wider tires can still rub on the control arms and such, so check and see where you are rubbing.
