Cummins Fuel Lines
Old Jan 21, 2008 | 10:54 PM
metrols's Avatar
metrols
Default Cummins Fuel Lines
I have a 93 W250 with a Cummins diesel. I have a steel fuel line leaking next to the block (low pressure) drip while running. My mechanic says he is afraid to try to replace it because he might break other lines in the process. Is the a kit that gives all the new lines for before the injector pump? Is the anything that will patch this? Any help would be great. Thanks in advance.
Old Jan 21, 2008 | 11:08 PM
Parts/Service's Avatar
Parts/Service
Default RE: Cummins Fuel Lines
Welcome to the forum. Dodge does not sell a fuel line kit that replaces every line. they only sell the lines as individuals.....Hope this helps.....DAVID
Old Jan 21, 2008 | 11:22 PM
metrols's Avatar
metrols
Any idea what these lines run cost wise?
Old Jan 22, 2008 | 01:47 AM
Mayfair's Avatar
Mayfair
Perhaps it's time for a big line kit
Big Line Kit
Old Jan 24, 2008 | 08:28 AM
CowboyBob's Avatar
CowboyBob
The fuel line should be 3/8" on the intake side. I bought 25ft of tubing from Jegs when I did my dual pump project and cut the steel line and spliced in my Aluminum tubing. You should be able to buy the fittings to do this form just about any auto parts store.
